Started on March 28 by Tristor
2017 Subaru BRZ Limited
Purchased in December 2017 as a Christmas gift to myself. See build thread here: https://www.ft86club.com/forums/showthread.php?t=125493 Parts Installed: Cusco Front Strut Bar w/ Master Cylinder Brace Cusco Rear Strut Bar K&N air filter Perrin Inlet Tube Shrader Performance Rear Seat Delete Perrin Wing Riser Kit AP Racing Sprint BBK in front, OEM brakes in rear CSG C2 (Front) and C1 (Rear) brake pads (track) Carbotech 1521 brake pads (street) Spiegler stainless steel brake lines Hard Brakes Titanium Brake Heat Shields Volk Racing ZE40 Time Attack Edition (18x8.5ET44) Yokohama Advan Neova AD08R 225/40R18 ARP Extended (3") wheel studs all around CSG Spec Racing Lug Nuts Jackson Racing Dual Radiator and Oil Cooler CSF Aluminum Radiator Filler Neck Samco Radiator Hoses APR Carbon Fiber Cooling Plate Stark Performance Automatic Transmission Cooler Fumoto Quick Engine Oil Drain Valve PTuning Lightweight Battery Tray Shorai LFX36L3-BS12 Battery (4.8lbs) PTuning Windshield Washer Reservoir Relocation Kit TRD Door Stabilizers Whiteline KCA434 and W0509 Front LCA Bushings (+0.5 degree caster) Whiteline KSR210 Steering Rack Bushings Whiteline KDT925 Differential Cradle Bushing Inserts Whiteline W63414 Trailing Arm Bushings Fluids and Filters: AMSOil Signature Series 0W-20 motor oil AMSOil Absolute Efficiency Oil Filter (EA15K20) AMSOil Signature Series coolant AMSOil Severe Gear 75W90 Gear Oil (in Diff) Redline D6 ATF Castrol SRF brake fluid Parts Waiting to be Installed: APEX ARC-8 FT86 Wheels in Anthracite/Gunmetal 17x9 +42 RCE Tarmac 2 coilovers w/ 400/400 springs SPL Parts Titanium Series Rear LCA SPL Parts Titanium Series Rear Toe Arms w/ Eccentric Lockout Vorshlag High Caster Camber Plates (Front) Vorshlag Spherical Shock Mounts (Rear Verus Engineering Side Marker Replacement Various wheel spacers (5mm, 10mm, 15mm) from Motorsport Tech Whiteline KDT922 Rear Subframe Bushing Inserts Parts on Order: STI JDM Transmission Mount STI JDM Engine Mounts Torque Solutions Driveshaft Center Bearing Solid Bushings AIM Solo 2 DL w/ Mount
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
4QIDG7dwTLopq3QpFRJlzK4R6LlgoOX0v1DhwdJDjtUHwBZ0MxLzfjBMxVT7gUET
