ae86andkp61
Corolla GT-S updates:
Engine reassembly in progress Apr 24, 2009
The oil pump is back on, the sump and windage tray are back on, the block is painted to match. We also removed the flywheel, which I was surprised to find out wasn’t much lighter than stock…I guess the free-revving was all due to internals, lightweight crank pulley, and higher compression. We replace the rear main seal as insurance. A 4A-G short block is pretty easy to flip over, so we just popped it off th stand to do this. :p
There was one stuck/broken off bolt on the intake side of the block which was a bit of a pain, but we got it without too much hassle, and only a little damage to the fresh gray paint.
A new water pump was assembled with new gaskets and O-rings, and placed on the block with associated plumbing and crank timing pulley also installed with a new key. Oh yeah, we got the head installed also with a new Toyota head gasket (more durable than a metal one, and we have enough compression from the pistons) but trimmed slightly to allow full oil flow to the head.
No cams installed yet, but I dropped some covers over the top to help keep dust out and just to get an idea of what it will look like once all buttoned up.
