ae86andkp61
Corolla GT-S updates:
Intake spacer completed Jan 8, 2010
I finished the plywood intake spacer/heat insulator. It is fully port-matched on both the manifold side and the intake side, and has been painted with about coats of high-temp enamel to help seal the wood from moisture. I hope it will make a bit of difference in terms of the torque curve and the density of the incoming air…just have to get the engine installed to verify that it works!
