ae86andkp61
Corolla GT-S updates:
More steering Dec 22, 2011
Here’s a peek at the underside, showing the new outer tie rods, adjustable at the end so I can finally try to minimize that last little bit of bump steer I sometimes feel. If you look at the outer end you can see that there is room for height adjustment, varying the height of where the tie rod connects on the outside end. Aluminum looks good, and might even help save some weight!
