Readers’ Rides:
2002 Chevrolet Corvette Z06
Added on Nov. 25 by rudyarias
Transponder: AMB TransX 260 #3902107
Modifications:
Engine: 6.6L LS2 GM Performance Parts #88958665 - CNC ported 243 LS6 aluminum performance heads GM Performance Parts #88958689 - LS Racing Roller Lifter Kit GM Performance Parts #12480033 - GM Gen III LS6 “Hot” Cam GM Performance Parts # 12593546 - LS7 front cover GM Performance Parts #12568820 - LS7 Crankshaft Melrose Performance Smooth Flow Tri-Y (long tube) Design Headers Melrose Performance X-Pipe Random Technologies Cat Converters Stock Titanium Exhaust Halltech Air Intake Blackwing Air Filter LS1 Ignition Wires Lingenfelter Oil Cooler Elite Engineering PCV Oil Catch Can Ron Davis Aluminum Radiator Part Number 1-16CV9799
PCM – reprogramming / fuel mapping by BV Performance, LS engine configuration and PCM fine tuned by Mikels Performance Engineering, LLC.
Dyno - 422 hp @ the wheels
Transmission: MTI Six Shooter Shifter C5R Delrin shift knob Spec Aluminum Flywheel and OEM Z06 Clutch Transmission – Micro Polished, Compressed Carbon Synchronizers, Compressed Carbon Rings, Bronze fork pads, RPM modified 1-2 shifter fork, Carbon Composite Reverse gear, rings and relocation of cooling return GM Performance Transmission / Differential Coolers, RPM installed transmission and differential mechanical pumps
Brakes: OEM ABS control unit calibrated to 55/45 brake bias with increased (15%) brake pedal pressure Self Designed Painted Front Brake Air Deflector Doug Rippie Brake Cooling Ducts CarboTech XP 10 Front Brake Pads CarboTech XP 8 Rear Brake Pads
Front: “J56” (C6Z06) PBR Six Piston, Rear: “J56” (C6Z06) PBR Four Piston Caliper Pistons: Elite Engineering Stainless Steel Brake Caliper Pistons Rotors – DBA 14” Front Rotors, DBA – 13” Rear Rotors Lines – Goodridge Stainless Steel Brake lines SSR Comp H 18 x 10.5 Wheels Tires: 295/35ZR18 Bridgestone Potenza S-02
Body/Frame: GM T84 Euro Head Lamps Phillips 4200º Hi/Low Xenon H4 headlight conversion GM Part Number #10365816 “Z16” carbon fibre hood 3M Paint Protection – Front hood (18 inches), fenders, nose and mirrors / Front Roof line (18 inches) / Rear Deck Engineered Corvette Products Frame Rails C5 Skid Plate Wheels Rear Corvette Painted Splash Guard Set Auxiliary Hood Seal Pratt Miller C5R Rear Spoiler
Suspension: OEM Springs GM Performance T1 Front Sway Bar Addco 27mm Rear Sway Bar 2004 “Z06” OEM Shocks (stiffer valving) C6 front and rear knuckles - R #88965638 C6 front and rear knuckles - L #88965637
Differential: Quaife 3:42 – Micro Polished
Interior: OEM Seats – modified, seat springs lowered and slots for shoulder harness Driver & Passenger TeamTech Six Point Harnesses Hardbar – harness bar AMEREX HALOTRON A384T Fire Extingusher Brey Krause R9115 Lap Belt Mount Kit for C5 and Z06 Corvette Wider “Z06” Polished Billet Clutch and Brake Pedals Elite Engineering “Heel & Toe” Gas Pedal
Comments
maddog23:
That was a good read. Impressive amount of work you put into her.
Dec 1, 2010 11:38 a.m.
You must be registered and signed in to comment.
Like this Chevrolet?
6 votes
You must be registered and signed in to vote.
Save & Share:
See more:
