Readers’ Rides:
2006 Subaru AWD WRX
Added on Jan. 31 by nmrortizwrx
Turbo compressor - 2,457 cc 2.5 liters horizontal 4 front engine with 99.5 mm bore, 79 mm stroke, 8.4 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder - Premium unleaded fuel 91 - Fuel economy EPA highway (mpg): 26 and EPA city (mpg): 20 - Multi-point injection fuel system - 15.9 gallon main premium unleaded fuel tank - Power: 172 kW , 230 HP SAE @ 5,600 rpm; 235 ft lb , 319 Nm @ 3,600 rpm
- 0 updates
- 0 comments
