1968 Saab Sonett
Started on May 24 by formulasaab
Ride Rating
10
It is really Dad's car, but I get to race it and help maintain/modify it.
In 1985, Dad finished restoring this Sonett. He always wanted a roadster but SAAB didn't make one. He decided to make his own!
Engine: 1500cc Ford V4. In race trim it's bored for a displacement of approx1562cc. Custom pistons put it at 12.5:1 CR. Solex 40 PII-4 carburetor with custom intake manifold. Cylinder heads are ported with big valves and valve springs that allow a redline of 7800 rpm. Hot cam means a peaky power range. A heavily modified cooling system and oil system keeps things cool and healthy. Straight exhaust (no muffler) and it is LOUD. Stock HP was 65hp, though we've never measured it I suspect we've close to doubled that number. Probably in the 115-120 range.
The chassis is stock with no additional bracing, though we've added a significant rollbar for racing.
Springs are stock ones with 2.5 coils cut off. Shocks are (vintage) Koni adjustable. I've dialed in a bunch of negative camber up front and run either 185-65-15 Hoosier Speedsters or 500-15 Dunlop L-Series tires depending on which club I'm running with.
Brakes and hubs are from a SAAB 96 Monte Carlo, which provides us with a 4 bolt hub and allows the use of MGB brake pads in front. Dual brake master cylinders with adjustable balance bar helps whoa things down.
The gearbox is a standard unit from a SAAB 96. The freewheeling is ACTIVE.
4 comments on this ride
Join Free Join our community to easily find more Saab reader's rides.
Comments
May 24, 2010 10:54 a.m.
hrdlydangerous:
I do believe I used to autocross with you at Gloucester County College.
May 24, 2010 1:08 p.m.
formulasaab:
Yup. With the BMC!
Nov 15, 2011 9:45 a.m.
JoeyM:
Fabulous!!
May 31, 2013 10:30 a.m.
Smitty:
Wonderful job on the car. I own 4 Sonetts myself. Most people never knew they existed.
You must be registered and signed in to comment.
Subscribe Today
Learn More
7PNd8GEMNkF9swOmgc9wr1Ste3vTa1w8qZphmWMWcFZuyZ5w0lgmbNIQCy0Qmfz1
