1984 Volkswagen Rabbit GTI Cup Car
Started on July 12 by vr6gtispeed
Ride Rating
7
The car was built by Erickson Motorsports in Ca. for the NASA GTI Cup class. I bought the car in Dec. 2009.
Specs: Suspension: Neuspeed 25mm Front Sway Bar Neuspeed 28mm Rear Sway Bar Bilstein Shocks Neuspeed Upper Tie Bar Neuspeed Lower Tie Bar Neuspeed Solid Upper Strut Bearings New Dimensions Front and Rear Poly Motor Mount Bushings New Dimensions Steering Rack Bushings New Dimensions A Arm Bushings
Motor: 1.8 l 8 Valve Inline 4, Mk-II GTI Throttle Body Autotech Cylinderhead, 286 Cam, Header Scientific Rabbit Stage III Intake Manifold New Dimensions oil Cooler Griffin Radiator Techtonics 2-3/4” Exhaust
020 close ratio 5 speed trans with a Wavetrac LSD.
Weight with full tank and driver. LF = 680, RF = 722, LR = 438, RR= 334 Total 2174 LB
Join Free Join our community to easily find more Volkswagen reader's rides.
You must be registered and signed in to comment.
Subscribe Today
Learn More
mSgXXbD4QFJwMHvLbqCAps9Ieey9keyWTQfTSwc3geoJ0ajYEWE0gGq0KUKYb87m
