Started on July 20 by BobShaw
1957 MG A
Its a bit modified. The engine is a 5 main B bored 60 over, fairly stout cam, cross drilled crank, flow job on the head. It runs HS 6 carbs on a Maniflow ceramic coated intake and header. It has a C overdrive transmission in a B case and is running a tube type B rear end. It is running lowered rally springs and delron bushings. The front brakes are from a 1600 and the rears are BGT. My friends started driving Miatas. I wanted to keep up. I can do that now
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
HPrUaCuPnz9465eLY6g2agADrKP076cAOlLxmIRtkUC3v2nbFy9jsW2OIp3kf7PJ
