Josh
1998 328i updates:
M bumper/paintwork Jul 22, 2009
I finally got around to replacing my cracked front bumper, and while I was at it, I repaired a small rust spot on the drivers side rear door. I also had the drivers sideskirt and nose panel sprayed to help it all blend in. I am pretty pleased with the result. Next up is a new driveshaft, 3.23 LSD diff, and a short shifter/overhaul of the shift linkage. Then hopefully I will leave it alone for a while :).
