1991 Mazda MX-5 Miata
Started on Oct. 11 by SneakyB757
Ride Rating
6
Engine Internal
-1.6 B6 long nose -rotating assembley balanced -Crank reground -Wiseco .060 over pistons -Eagle H beam rods -ALC Race bearings -ARP Head, Rod, and Main bolts/studs -Boundary Engineering oil pump gears -OEM new Water Pump -OEM new balancer -Full New gasket set -OEM new valve seals, valves freshend up -Super Tech Dual valve springs -Super Tech Titainium retainers -FelPro multi layer steel head gasket -Kelford 272 turbo grind cam shafts -Corksport Cam adjustable cam gears -Gates Racing timing belt.
Drive Train
-XTD Prolite 9lb flywheel -ACT XT Pressure Plate -ACT 4 puck sprung hub -Torsen LSD, 97 axles and drive shft
Turbo + Misc Stuff
-Garrett T3 60-1 .48 hotside w/ 4" K&N filter -ETD tubular shorty manifold -3" Custom turbo back exhaust -Tial 38mm wastegate -Tial 50mm Blow off valve -CXRacing intercooler 24"x10"x3" -2.5" i/c piping w/ all tbolt clamps -Godspeed Racing aluminum radiator w/ 2 12" slim fans
Fuel / Electronics
-MSPNP w/ 4 bar map sensor -AEM Wide band + gauge -Auto meter 30/30 boost gauge -Walbro 255 fuel pump -RC 750cc injectors -Magnacore 10mm spark wires
Suspension
-Ebay adjustable coil overs
Wheels and Tires
-16" Drag DR13 BF G-Force KDW 225 drag radials in the rear, Kumo Escata's in the front
Im currently running 20psi on a conservative fuel and spark tune. Not sure about numbers at this point havent gotten a chance to dyno it yet.
2 comments on this ride
Join Free
Join our community to easily find more reader's rides.
Comments
Dec 23, 2011 7:56 a.m.
Lamps3:
Amazing modifications. What about your exterior, wheels, spoilers?
Jun 18, 2013 8:52 p.m.
Pete Gossett:
Good God that's beautiful. So much so that you're making me reconsider my "no white cars" mantra.
You must be registered and signed in to comment.
Subscribe Today
Learn More
jxNv7rPDkOnBgG42ZEp25ptpsjCac5wI
