2003 Subaru WRX - 2.61L Hybrid
Started on Dec. 2 by skimobile
It's been an ongoing project since I bought it new in 2003. It's a HPDE & autocross toy, daily driver, and soon to be hillclimb tool after the snow melts from the VT/NH ski areas in the spring. List of Mods: Engine Justice Racing Engine - balanced/blueprinted STI 2.61L stroker, ported EJ20 heads: Brian Crower Pro Series 83mm Stroker kit - 4340 billet steel crank, 100mm forged CP Pistons, Pro Series billet rods, ARP fasteners. ACL Race Series main & rod bearings Ferrea Comp Plus valves, titanium valvetrain, Cosworth 275 duration 10.2mm lift cams, Modified 12mm oil pump, Cosworth head gaskets, STI timing belt, water pump, oil pan, pickup, baffle, oil cooler. Group-N STI - 5 speed transmission mount, engine mounts, and pitch rod stopper Reflash by Matt @ Dent Sport Garage (DSG) Perrin light weight crank pulley and oil catch can. HKS oil cap, Optima Red Top battery Fuel Delivery Aquamist water/methanol injection kit with JDM Sti trunk mounted 12L reservoir Walboro 255 lph. fuel pump Aeromotive adjustable fuel pressure regulator with NOS FP gauge, AN-06 hoses, fittings and adapters Perrin fuel rail kit Power Enterprise 800cc twin nozzle injectors Spark plugs (NGK Iridiums - one setting colder than stock) Intake, Turbo, Exhaust and Coolant APS DR-725 Front Mount intercooler assembly Perrin Signature Series recirculating blow-off valve Agency Power 3" hard turbo inlet pipe. Perrin Big MAF Intake kit Deleted TGV valves, ported TGV valve body, blue powdercoated intake manifold ATP GT3076R externally gated turbo with TiAL MVR wastegate (.9 bar pressure) & custom dump tube INVIDIA equal length header / up-pipe combo Perrin 3" cat-free downpipe (with MIL eliminator) & Mad-Dad Wisper cat back exhaust. Grimmspeed Electronic Boost Controller Cusco heavy duty exhaust hangers Koyo Racing aluminum radiator, Mishimoto silicone upper and lower radiator hoses Mishimoto aluminum fan shroud and fans Turbo-XS aluminum radiator shroud Powertrain Andrewtech Ratio PPG helical gearset with billet shift forks and PPG Torson front LSD; braided SS clutch hydraulic line, The Driveshaft Shop Level 5 (750 hp) Front Axle set, KAZZ 1.5 clutch-type rear LSD Exedy WRX Stage 2 Single Plate Cerametallic 3 Puck Clutch(Thick) & ACT Streetlight-XACT Flywheel Brakes, Suspension, Wilwood big brake kit c/o: 6 Pot, Superlite 6 Billet front brake calipers, 12.9" slotted rotors 4 Pot, Dynalite Billet rear brake calipers, 12.19" drilled & slotted rotors Braided stainless steel brake lines, MOTUL brake fluid, EBC Yellowstuff brake pads TURNINCONCEPTS - Klunk Killer "Race Pkg." rear diff & outrigger poly bushings + Kartboy subframe lock-down bolts Perrin master cylinder support brace Tein Flex Coilovers Tein Electronic Damping Force (EDFC) Controller with M12 front / M14 rear stepping motors Cusco Type OS front & rear strut tower braces Perrin 25mm adjustable front/rear sway bar kit with solid end links and Positive Steering Response System (PSRS) Wheels, Tires SSR Comp, Gold 18" X 8" wheels with Gorilla blue anodized aluminum racing lugs Dunlop Direzza Sport Z1 Star Spec tires 235/40R-18 91W BSW Exterior Kaminari body kit - urethane front air dam with carbon fiber front splitter, fiberglass side skirts, urethane rear skirt. SEIBON CW-II carbon fiber hood, Tein hood dampers, SEIBON carbon fiber rear trunk lid & rear roof spoiler KSTech black hood scoop delete APR carbon fiber adjustable rear spoiler and APR carbon fiber front canards and APR rear diffuser Chargespeed carbon fiber Aero mirrors Bosch AERO windshield wipers Hella horns (blue) Lightwerkz - custom HID projector headlamps, Phillips D2S bulbs, Angel-eyes, Denso D2S ballasts, JDM Fog light covers. ProjectSoloGear - 3/16" aluminum skid plate with access panels Subaru JDM STI Spec C Roof Vent Interior MOMO Supercup driver / passenger seats, custom seat rails, Schroth Profi II ASM 4 point harnesses, Prodrive floor mats, custom rear blanking panel, Autopower 6 point rollcage, BSCI FIA homologated roll cage padding Amerex 2.5lb. dry chemical fire extinguisher with custom floor mounting MOMO aluminum clutch, brake, gas & dead pedals and MOMO Raptor shift knob Lamco column mounted boost gauge Carbon fiber 60mm center gauge pod and AEM UEGO Wideband O2, oil pressure, oil temp. gages, Greddy (oil temp & pressure) sandwich adapter Two 5.25" Crossfire front door speakers Escort Redline radar detector, Blinder M47 X-treme Laser Scrambler, TomTom - GO 920T portable GPS.
See more:
You must be registered and signed in to comment.
