Started on May 11 by Graham Blackwell
1983 Ford Fiesta XR2 Mk1
15
Race Car, built for Hillclimb and Sprints in the UK, as featured in August 2006 GRM magazine. Back then it had a Zetec engine, producing around 180BHP, but never satisfied, I changed the engine in 2008 for a Ford Duratec, and also decided to rewire the car for the 2nd time, and make various other changes to make it more competitive. Chassis is a 1983 Ford Fiesta XR2, transplanted with a 2008 2.0 Ford Duratec DHE420 engine from the European Ford Fiesta ST150. Titan barrel throttle bodies with 100mm air-horns. A Titan fuel rail delivers fuel to the cylinder head, and the car features Fuel injection running the IW031 injectors in batch mode. The sparks are provided by Coil On Plug modules, individually controlled by the DTA S80 ECU. Tony Law 4-2-1 race exhaust system. ARP conrod and flywheel bolts, a Titan Superlight flywheel (3.7Kgs), and an AP Racing cerametallic paddle clutch and competition clutch cover. It has a self built wiring loom, using nomex sleeving throughout. At the rolling road in May 2011, we recorded 200bhp and 160ft/lb using a 7600rpm rev limit. In February 2011 I installed a prototype five speed Quaife sequential front wheel drive transmission. I am aiding Quaife with the R&D of the new gearbox. Kustomengineering.com race suspension featuring alloy heims and adjustable arms throughout. The front suspension uses 2.25” coilovers, with 275lb springs, and the rear axle has 450lb springs and retains the panhard rod setup. Externally the car has a carbon fibre bonnet, Perspex (poly) windows, GRP tailgate, and GRP wheel arch extensions. Sprayed in Ford Sunburst red in 2000. She weighs 695 Kg, and has a power to weight ratio of 292 bhp/tonne. 0-60 in 5 seconds Self designed carbon fibre dashboard, with Stack instruments, Momo steering wheel, Quaife Sequential gear lever mounted on custom made 5” tall alloy tower and a RaceLogic gear display. 15” x 7” OZ Superleggera rims, and Michelin slicks all round. Focus rear disk conversion, HiSpec alloy 4 pot calipers up front, and 2 pot calipers at the rear.
Latest updates
July 25
Llandow sprint, July 16th 2011
BARC Wales Llandow Sprint 16th July 2011 5:00am depart 8:10am arrive 164 miles 33.0mpg Fiesta …
June 28
Aintree Sprint, June 25th 2011
First event in the Fiesta at the Aintree (Liverpool) Sprint on Saturday 25th June. No …
June 15
Engine mapping completed
Great day at NHM yesterday, where Troy worked his magic on the engine map. No …
May 16
All ready for testing
All done. Loaded up on the trailer, and just need to book myself in at …
May 13
Fitted the new suspension
Fitting the new Kustomengineering suspension at the moment. Found that the brace on the passenger …
Join Free Join our community to easily find more reader's rides.
Comments
integraguy
Feb. 6, 2012, 4:19 p.m.
OMG!!! as the former of a red 1980 Fiesta...I love your car. If I had the money and wherewithal, I think I would have done many of your updates on a car like mine. (I currently don't have a Fiesta, but am always on the lookout for another one.)
Gabrieljasik
Jan. 11, 2016, 8:43 p.m.
Sweet car! Where did you get the lip and fender flares? I'm wanting to put a zetec in a fiesta I have in storage, do you have a harness diagram to use the oem harness and ecu? Any help would be greatly appreciated!
Add your comment
See more
IgeNUpGowSJQYtOtMrxo8jYZcccyetU3TWAD9RbsTnjkCXpKX0aQGjEL2Nhdo3pi
