1993 Honda Civic cx
Started on July 18 by rustysteel
Ride Rating
3
Just bought a stock Civic cx hatchback for daily driving and autocrossing. Looking forward to playing with it.
4 comments on this ride
Latest updates
Sept. 10
Making Panda lighter
I've decided to make a dedicated autocrosser and my '93 Civic is it. Starting by making it lighter, rear seats out and going to remove whatever I can to make it under 2000lbs, the tow rating for the Legacy. No ...
June 10
Second Solo 2012
Had a great day and ended up 1st in HS and 1 st overall after PAX. Got a leaking axle seal (again) still ran well. Might be the last one with Panda as I have my eye on a sweet ...
April 23
First solo 2012
Almost rolling over.
March 26
started up the Honduh.
Well got the engine back together and it turned over no problem. We realized the thermostat was stuck so I put in a new one. All is working and temps are good. I'm trying to get the axle bolt off ...
Jan. 22
and more headgasket news.
Don't buy cheap head studs, they break. I realize now the OEM one's would've been a better choice after we broke one of the studs. No big deal but had to use the old ones which torqued up no problem. ...
Jan. 05
Had a friend, someone who knows what they are doing, help me. Got the head off and yes the gasket was toast. Took the head to the local machine shop and it is good and now looks brand new. Re-install ...
Dec. 28
Smokey civic.
Head gasket went so I'm in the process of fixing the car. Of course it's going to go down to -9 this week. Should have it up and running soon, I'm hoping to fix the CV and maybe upgrade the ...
Sept. 18
Fall Ball Solo
Just ran the Civic in it's second solo. Ended up 2nd after paxing, damn those Miatas. Great day, one more to go and the season is over. Time for ice racing. Maybe. I also added my rust inhibitors aka, Grassroots ...
Aug. 11
First run with the Civic.
Here's a little video of my Civic (before I bought it) sharing a ride. This was the first weekend in May and it was cool. You may have guessed that by the slide. Also listen for the abundance of horn ...
Join Free Join our community to easily find more Honda reader's rides.
Comments
Aug 16, 2011 9:36 p.m.
rustysteel:
My first solo with the car (as an the owner). Ended up first overall, thanks to the PAX system. We only had 10 entries at our local event as there were many races on the same day. Let you know how it goes for the next one.
Oct 13, 2011 5:54 p.m.
rustysteel:
Last solo of the year on Sunday. Over the winter I hope I can do a few things to the car. Hard to work on it when it's your daily driver. Scored some used R888 for next year. Next up a rear sway bar.
Oct 21, 2011 9:19 a.m.
rustysteel:
Things didn't go quite as well for the last solo. Ended up 6th out of 29 entries. Not bad but had a spin and almost hit the wall. We were running on the oval and I went in to hot and lost the back, got about 1-2 feet from the wall. After that I was a lot more conservative and my times showed that. Next year I'll run the r-compounds and hopefully a rear sway bar.
Apr 23, 2012 3:11 p.m.
rustysteel:
3 broken breaker bars and using the torch and the axle nut is off. That was fun. I put it back together and the transmission gasket is leaking so I've pulled it apart again and waiting on a replacement. I did run the first solo of the year. 34 cars and I was first in HS and 2nd overall. Not a bad day for a rollie pollie Honda Civic.
You must be registered and signed in to comment.
Subscribe Today
Learn More
qGLKwgHmwsk8QQkx5KMyblNVSLkbLgkSqaILJJUWoBngbQ0vFxUHiFG6bcbOSDHy
