1988 Mazda RX-7
Started on Aug. 16 by ryannterror
Ride Rating
12
Cars was built for time attack and hillclimbs. Fabrication and machine work was done by me RTM Performance.
Engine The car has a GM 3800cc, V6, Ported heads, turbocharged and intercooled. RTM Performance 321 stainless turbo manifolds, RTM Performance 321 SS turbine outlet with 3.5-in. side-exit exhaust, Precision intercooler, RTM Performance V-mounted radiator/intercooler.
Engine Management Vipec V88 ecu with drive by with using Subaru Electronic throttle body and foot position sensor, Anti-lag, flat shift.
Drivetrain G Force shifter, G Force straight cut dogbox transmission, 6 puck unsprung clutch, Ford 8.8 solid axle, Ford Racing rear carbon clutch diff
Suspension
Front RTM Performance front struts, Bilstien 46mm dampers with hyper coil springs, RTM upper mounts, RTM tie rods/ends, manual steering rack, RTM steering column, bladed adjustable 1.000-in. anti-roll bar
Rear RTM Performance Ford 8.8 one off 3link setup, Bilstien 46mm dampers with hyper coil springs, RTM Performance Chromoly lower arm with Milspec rodends, bladed adjustable 0.875-in. anti-roll bar
Brakes
Front Willwood Forged Superlite caliper, Evo VIII cryo-treated rotors, Willwood PolyMatrix A pads
Rear
RTM Performance Willwood caliper brakets, Willwood Forged Superlite caliper, Evo VIII cryo-treated rotors, Willwood PolyMatrix A pad, RTM Willwood 2 piston caliper hydro ebake setup
External
Wheels BBS 17×10 17×12 3pc magneisium
Tires Dry: Hoosier 295/40R17 (F), Hoosier 315/40R17 (R)
Body
Re Amemiya SC2000 front bumper, Re Amemiya rear difuser, RTM Performace drop vent hood, RTM side skirts, RTM drop rear vent fenders
www.rtmperformance.com
Join Free
Join our community to easily find more reader's rides.
You must be registered and signed in to comment.
Subscribe Today
Learn More
wRl29GD5m1S3rRUNLeXIlHE19pKC1kUs
