vweezly 1982 Rabbit updates:
Turbo back on Mar 12, 2009
Monday night I did a crap ton of welding. Found a bit of rust on the drivers side rocker near the pinch weld…. turned into a bit more than I thought. Patched it up and rebuilt the pinch weld and part of the floor pan. The welds really suck so it’s a good thing it’s under the car.
Reinstalled the turbo and hooked up all the lines. Bolted on the DP and it’s all good to go. Just a few more things to attach. Wideband needs to be screwed back into the dp. Need to reinstall the wastegate and attach the vacuum lines.
OH… and I decided that I am going to do this to relocate the air filter…
