Readers’ Rides:
1991 Mercury Tracer LTS AWD
Added on Dec. 21 by kcbhiw
Built for the Grassroots Motorsports $2008/$2009 Challenge
Front Suspension
Mercury Capri Front Knuckles
Ford Aspire Front Spindles (4x100 Conversion)
Spherical Tie Rod Ends
Mazda 626/MX6 Front Control Arms
Mazda Protege5 Tein Struts
Mazda Protege5 Top Hats
Rear Suspension
Mazda Miata Rotors
Spacer Added to allow GTX Calipers work with Miata Rotors
Mazda Protege 5 Tein Shocks
Mazda Protege 5 Top Hats (Modified to correct Camber angle)
Chassis
Modified/Notched Front Subframe to clear Transfer Case and transmission
Modified/Notched Front Crossmember to clear transmission
Raised Steering Rack 3/4” to clear transfer case
De-Powered Steering Rack (Properly)
Steering rack moved forward 2” and tilted rearward 39* to clear trans
Mazda 323GTX Rear Subframe
Drive Train
Mazda 323GTX AWD Transmission, Axles
Mazda 323GTX Rear Differential, Axles, Lateral Links
Lengthened Mazda 323GTX Drive Shaft
Custom Front Axle Half-Shaft Mount with GTX Halfshaft
Mazda 323GTX Shifter and Cables
Engine
Rotated Engine Back 8 degrees to allow fitment of GTX Transmission
Custom Transmission Mounts (3)
Modified Pass. Engine Mounts
Custom Log Turbo Manifold
Ford Thunderbird T3 Turbo
Custom Downpipe
Megasquirt PnP Standalone Management
No-Name FMIC and Piping
Mazda 626GT BPV
Exterior
Ford Escort GT Side Skirts
Mazda 323GTX Grill
Repainted MClaren Silver
BMW E30 “Bottle Cap” Wheels
Misc.
ATL 11 Gallon Fuel Cell
Stripped Interior
AWD Transfer Lock Mounted in Place of Radio
Deleted/Filled Antenna Hole
Goodridge Braided Brake Lines
Comments
Volksrodden:
Have you re-inforced the front frame rails? they do have a history of cracking, mine did back in 99. I guse this had happen to alot of them.
Dec 24, 2008 4:22 p.m.
kcbhiw:
I haven't heard of this. I'll definately keep an eye on it!
Jan 13, 2009 10:57 p.m.
dok33:
Awesome build! Read the whole thread on mazdas247 a while back, can't wait to see it in person!
Sep 23, 2009 10:10 a.m.
You must be registered and signed in to comment.
Like this Mercury?
16 votes
You must be registered and signed in to vote.
Save & Share:
See more:
