Readers’ Rides:
Ford Mustang Cobra
Added on Jan. 19 by birel21y
GT40 UPPER / LOWER INTAKE GT40 HEADS FORD RACING E303 CAM FORD RACING DUAL VALVE SPRINGS ALUMINUM UNDERDRIVE PULLIES HIGH VOLUME OIL PUMP KING COBRA CLUTCH CORBA FLYWHEEL FORD RACING ALUMINUM DRIVESHAFT FORD RACING 3:55 GEARS ARP STUDS / BOLTS BBK INTAKE SALEEN RACECRAFT WIRES C&R RACE RADIATOR OPTIMA YELLOW TOP BATTERY CRANE CAMS FIREBALL IGNITION BBK SHORTY EQUAL LENGTH HEADERS BBK X PIPE BORLA XR-1 CAT BACK BLUE COIL SPRINGS KONI YELLOW ADJUSTABLE STRUTS / SHOCKS ENERGY SUSPENSION URATHANE BUSHINGS BBK REAR CONTROL ARMS AGR 15:1 QUICK RATIO RACK & PINION HOTCHKIS ADJUSTABLE CAMBER PLATES TOYO RA-1 TIRES FORD RACING COBRA R RIMS COBRA 13” BRAKES RACETECH 45G FIAVIPERSEAT RACETECH PRO 7 POINT FIA HARNESS RACETECH FIA 5MM BRACKETS AUTOPOWER 6PT ROAD RACE CAGE
Comments
Lamps3:
WOW, You have been busy updating this car for the road course!!! What year is the Cobra it is hard for me to tell with just the one picture?
Mar 27, 2011 9:49 a.m.
You must be registered and signed in to comment.
Like this Ford?
5 votes
You must be registered and signed in to vote.
Save & Share:
See more:
