Started on May 30 by blozup
1977 Datsun 280Z
For some reason I decided to swap in a VG30ET out of an ‘88 300ZX (the same V6 in every Nissan in the 90s, really) I made my own exhaust manifolds, bigger turbo, fuel pump, injectors, lots of piping everywhere. It was a lot of work for the 240HP at 18psi it made on the dyno. No, you read that correctly. It made 170HP at 9psi. So, currently I spent thousands of dollars and lots of hours of labor for the nearly the same power level I had with a stock L28. I have deduced that the donor engine might have some issues. But, well, that’s why I’m building another engine up right now.
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
cdkwk1KBH2WBCGUPni30X6W7WnrrmJ43UtozrbNlsQ231QacQGz7T9QKny6lFKpw
