ditchdigger
1971 850 Berlina updates:
driving straighter Jan 10, 2010
Did a driveway alignment today. I shimmed the upper control arms out to remove some of the negative camber. I still need to adjust more out. took it from 4.2 on the drivers side and 4.58 on the passenger to 2 degrees even on both. The little angle gauge from horrible freight is made for setting up table saw blades but is awesome for this. I made a fancy jig but it proved to be no more accurate than holding it flat up against the lug face.
then I set up the string gauge, centered the steering linkage and set toe to zero or as close as I could measure with the crude setup.
I needed to simulate my weight somehow and the tires and wheels were there so….
The little eight and a half now tracks straigt and true. I could even take my hands off the wheel if I dared.
