Removing outboard CV joints from axle halfshaft
Suggested by Tyler HThe axle halfshaft on most newer cars is attached to the outer CV joint by a circlip that is concealed once the CV joint is snapped onto the axle. Over time, it becomes almost impossible to separate the two and the outer joint is considered a “non-serviceable part” most factory service manuals.
I wanted to make a custom axles for my Toyota MR2 Mk1.5 project, so I bought some new ebay axles from an ‘88 Camry V6, but I needed to get the joints onto a 91 MR2 halfshaft.
To separate the outer joint, I figured out that you could slide the whole axle into a pipe, such that the ballrace from the outer joint was resting snugly against the pipe. One good overhead thwack, and the two are cleanly separated.
Video: http://www.youtube.com/watch?v=Yz0x6LNo6HY http://www.youtube.com/watch?v=pTooPkTAmIk
Aug 26, 2008 12:35 p.m.
