Dead electric pump?
Suggested by noisycricket
If percussive maintenance doesn’t get it working again, try momentarily reversing the power to the pump assuming that it has a non-permanent ground. Sometimes it works… sometimes it doesn’t… but if it’s easy to get to, it’s worth a shot.
Hammering seems to mainly work if the brushes are worn out or stuck in their holders, reversing power seems to work if the pump is physically jammed on its own innards or the commutator has a burr on it.
No one has posted any comments yet. Perhaps you'd like to be the first?
You'll need to log in or register to comment.
