Stop the Glare!
Suggested by firefly1_0
If you have glare issues at the track from your dash or hood you can spray problem areas with some Arrid Extra dry in the aerosol till its less reflective.
Comments
GameboyRMH:
Another tip: If you're getting glare off a painted surface inside the car, get some cheap rattle can acrylic clear coat and add a light coat. This cheap crap goes on more like frosting than a clear coat and reduces glare (adds a hard coating too). Just make sure you're wearing a mask while you spray that stuff x_x
Nov 11, 2008 7:26 a.m.
soulshinobi:
Preventative maintenance when detailing the car would be to be sure to only clean the dash with a moist cloth, no Armor All or the like. I've seen more serious people remove the dash, use a spray-on adhesive, then spray-on black nylon fibers to keep glare down. It gives a carpeted look, similar to the felt dashes on many race cars.
Jun 5, 2010 12:54 a.m.
You'll need to log in or register to comment.
