flooding carbs
Suggested by Roto_BIn the Dec 08 GRM when discussing start up problems on new engines & they discussed flooding carbs.Remember that the float system works like a toilet.Yes a whack to the carb may do but I have found that shuting off the fuel supply by pinching off a possilbe rubber feed hose or electric supply to the fuel pump.when the car runs out of fuel the carb float bowl will be empty & the needle will be fully open.When the fuel supply is returned,the incoming fuel will wash the needle area clean & stop the fooding situation.
Jun 29, 2010 11:16 a.m.
Sep 2, 2010 11:07 p.m.
