Harmonic balancer bolt removal
Suggested by wheelsmithy
Figured cthis out on my toyota 22-re. To remove balancer bolts in the rough/without air, Put a breaker bar on the bolt(with proper socket-duh), brace as best as you can, and simply crank the engine. Breaks the bolt loose like a charm. You honda/corvair folks might want to beware. This is untested on those reverse rotationengines.
No one has posted any comments yet. Perhaps you'd like to be the first?
You'll need to log in or register to comment.
