Oversize Brakes
Suggested by LocostSmitty
When adapting oversize brakes to your car, take some washers and put your lug nuts on backwards, you can secure your rotors to your hubs. If you make an adapter to go from your brake line or bleeder to plug into your air line. Cut a strip of corrugated card board to go on the circumference of your rotor to maintain clearance to your caliper. Place your caliper where you want it (with the pads in place) and apply air pressure to it via the adapter. This uses the caliper as an air clamp allowing you to measure, make up, and/or weld whatever mounts or adapters you need to get the calipers to bolt to your spindles. This won’t hurt your calipers as shop air goes 100 to 150 psi., and brake systems normally run 1000 to 1500 psi. Smitty
Comments
wheelsmithy:
Verynice!
Dec 16, 2009 5:39 p.m.
fabron:
LocostSmitty, you da man!
Sep 2, 2010 10:54 p.m.
KATYB:
honestly never ever thought of this…. very smart.
Mar 21, 2011 5:24 p.m.
You'll need to log in or register to comment.
