Classic case of horses for courses I think.
I thought it was fitting that he mentioned he wasn't driving a formula car as 90% of my left foot braking is in formula cars.
Photograph by Kevin Adolf
My left-foot braking column is making the rounds again, and I’m glad to see it’s sparking discussion. I think all we need to do is look around the community and see that there’s certainly not one single “right” way to go fast, but I hope for those of you who have read this, it at least opens you up to the possibility of experimenting with different techniques.
One fantastic response I got was from BimmerWorld’s James Clay, who certainly knows a thing or two about going fast, and his perspective is below.
One key difference I see in our overall approaches comes from our missions of the moment. While I spend most of my time on track currently in a time attack format, chasing a single fast lap, James is contending for wins in races that are hours long.
My mission is ragged-edge grip and performance in a narrow window, while his mission is consistency, repeatability and predictability over the course of hours. It’s interesting to see how seemingly minor factors can come into play when those two different approaches are weighed against each other.
So, enjoy James’s rebuttal–well, combination validation/rebuttal/alternate perspective–to my current left-foot addiction. There’s some neat stuff to chew on here:
After years of hearing the benefits of left-foot braking, and some iterations in equipment allowing more complete adoption (sequential transmissions and, more recently, paddle-shift cars), I can tell you it’s been a journey.
In the early days with an H-pattern standard transmission, I struggled to find the benefit–the tires can only do so much work, and it’s easy to overload them when adding inputs (and work requirements).
I spent a tremendous amount of time left-foot braking street cars to calibrate that foot, more often used for on-/off-clutch inputs, into a useful tool. The results for me were a fail. Even in a car with a racing sequential where I used the left foot at times (especially to combat knockback on the brakes), it never showed an overall benefit in lap times for a single lap–or a session.
Then we got our first M4 GT4 with a DCT transmission. A factory car with tuning for shifts both up and down, a manual pedal box without a booster that I could wail on, and turbos that liked the throttle plate opened early so they were ready to make power when needed–the perfect foundation to make left-foot braking work.
Immediately I found (thanks to the non-boosted pedal) that the hardest part of adopting left-foot braking was where I put my left foot when I left the pits. If I had it near the brake in the first braking zone, that was where it remained and there was no thinking required for which foot I would use.
And surprisingly the biggest benefit I found (again, with the non-boosted brakes) is that my left foot was ready to turn the brakes ON–and interestingly, even though I was no longer rev-matching for the DCT transmission, my right foot while braking had too many years of programming to blip a throttle, which showed up as small variations in brake pressure.
The left foot was the hammer, and my right foot was too variable. I was also able to continue on this journey when I started driving the BMW M240i Racing with a boosted pedal, which allowed (and required) refinement with a more delicate pedal approach.
In this era, my braking became more consistent, my taps before braking for knockback were easier with less dancing on the pedals, and I started to experiment with the right amount of overlap to get the turbos ready mid-corner to optimize power out of the turns–all wins.
But after a year and change, I noticed the other side of the coin: the problems I was also causing.
I was prepositioned over the brake pedal while accelerating into the braking zone and deployed the left-foot hammer immediately–but I’m not driving a formula car, and the car wasn’t ready for the abrupt transitions.
There is value, even with a stiffly sprung race car, in time to transition the weight. And while this can be done with thoughtful application rate, there is also some value in a minimal pause time while all this is happening. (I know, time coasting is time lost, but it’s not that absolute.)
I had also worked on overlap (the way I came off the brake pedal in trail braking and when I came onto the throttle to spool the turbo), and it did help turn exit–at times. But the undesired side effect is, while cracking the throttle does start the turbo spool, it also moves you off the decel ramp in a typical clutch-type limited-slip and, worst (and most typical) case, onto the accel ramp, increasing diff lockup and affecting the mid-corner phase of the turn.
So your turbo is ready to make the power, but you’re waiting on an induced mild push to be able to fully apply it–again, in very small amounts. And all of these things, which added another input into the mix when the driver is giving bits of two pedals at once, were also hurting the tires, both immediately (a tire can show small effects of grip loss due to load for a corner or two until it cools back off) and over the span of a stint.
Then, an eye-opening moment came when Bill Auberlen joined our team and added his data to the pile for dissection. He’s not a left-foot braker. And once I saw that and started paying attention, I understood that very few elite drivers are, and not for the reasons above only.
Of significant concern when adding more throttle use, both deeper into the turns and earlier coming out of turns, is fuel use. This may not be a concern for most drivers not looking to stretch a stint another lap, but it’s a factor. And while working through the data, removing the left foot from braking (other than standard knockback tapping) wasn’t slower!
And through a year of going back and forth on foot use for both myself and some of my teammates, all under the watchful eye of our engineer, the clinching moment for me was when our engineer told me that I was losing out over a stint due to the tire energy expended by asking too much–0.1 or 0.2 a lap, so it wasn’t much, but I think very few drivers are in the habit of accepting any level of loss.
So where am I now? I can produce very similar lap times with left- or right-foot braking, and I have to make a conscious choice on which to use because I’m comfortable with either.
I know I’m slightly faster and make tires last longer (longer in the performance window–this isn’t a consumable tire wear concern) when I right-foot brake–and I do.
The left foot continues to handle knockback taps before every braking zone. And in some very rare instances, I still use left-foot braking on a very few specific braking zones because they are extremely high-speed, I’m busy for some reason in the car, and I want the confidence that when I pull the trigger and drop a foot to brake, the brake pedal will be squarely under it with no concerns of my foot slipping or not being able to hit the needed pressure for an intense application.
This makes me feel better about not pursuing left-foot braking for the foreseeable future. I would have to be well-seasoned and well-practiced (like he did) in order to make it truly viable for me. I'm just not there yet. Great article and I enjoyed reading about his experience with the technique (JG as well).
The only place I've done much left foot braking is at DirtFish. Rally uses the brakes in entirely different ways to road racing. :)
Yes and I occasionally use rally LFB to combat understeer.
My son was shocked when I used this technique when we autocrossed his LS400.
At VIR I only LFB in T3 & just before the apex of T16 so I can keep the car balanced in a sweeper. At T10 it is really just too scary for me, in case I get it wrong.
On low grip surfaces like rain or even snow, sometimes it's the only way to get the car to turn (like driving on track with slicks when it is damp).
LFB has kept me out of the tire wall when sliding on grass after going off if you only need a few degrees of yaw.
Hmm,... Left foot braking sounds like one of those performance driving techniques you need to master as well as heel-toe downshifting, right? In a recent GRM article about left foot braking I learned from one of the commentors that applying a bit of throttle could settle the rear of the car if it was skittish when hauling it down from high speed. Having experienced this phenomenon, I looked forward to trying out left foot braking the next time I was on track and the rear end started to skitter.
The other day while perusing the manual for my 1st Gen FR-S I read: "When the vehicle is being driven with the accelerator pedal depressed, depressing the brake pedal without releasing the accelerator pedal will activate the brake override system to restrict driving torque."
Huh. Did they take my fun away?
Now, the manual specifically says "... depressing the brake pedal without releasing the accelerator,..." Using left foot braking to settle the rear end would be executed by depressing the accelerator without releasing the brake.
Anybody know if the pedal sequence makes a difference to restricting driving torque?
Anybody know if restricting driving torque is achieved by automatically engaging traction control (bakes), or by reducing throttle angle (or fuel cut)?
Can I tune this out of existence?
Thanks to J.G for making wild claims about left foot braking to the masses and James Clay for sharing his insights with us!
In reply to Nred :
Yeah I wasn't aware about the BRZ/86 having a throttle cut, but it's definitely a thing. The Civic R has one as well, which is super frustrating because it's a high-powered turbocharged FWD car which is definitely a format that lends itself to LFB in autocross situations.
I'm honestly not sure what tuning is available to defeat this in cars that have it. Maybe someone that has an affected car can provide some insight if they have any experience. I'm doubtful there's much to be done to defeat this function, though, as it's probably a part of the programming fairly tightly locked away from any third-party software.
Blame the folks that love floormats so much that they put floormats on top of their floormats, and don't understand how to deal with a car with a stuck throttle.
Displaying 1-10 of 12 commentsView all comments on the GRM forums
