wae
wae PowerDork
5/19/23 8:06 a.m.
It doesn't really matter one way or the other for me - the car is already under $2000 when including these parts and it's also a bone-stock 1990 Saab Convertible with an automatic transmission, so it ain't going to win any awards, if you know what I mean.  But...  Just because I'm curious I thought I'd ask:
The Saab uses a hydroboost-like setup for the brakes where the power assist is not from vacuum but instead uses a electric pump to pressurize the brake fluid, an accumulator to hold a few thousand PSI of that built-up pressure, and a pressure switch to tell the pump when to run.   The pump is fine but the switch and accumulator were failed so I replaced them with OEM-style replacements.  They're both attached to the master cylinder and are pretty well required for brake function.
Would those components be budget-exempt just like "Brake friction materials, lines, calipers, master cylinders, boosters, rotors and drums"?  I would assume that these would fall under the "boosters" category, but I'm not replacing the whole thing since there isn't a single "booster" on the car, but these bits that are bolted up to the master cylinder.
Stampie
5/19/23 8:20 a.m.
I'd say exempt.
5/19/23 8:33 a.m.
Exempt
Tom Suddard
5/19/23 9:19 a.m.
Exempt. Please show up with safe brakes.
wae
wae PowerDork
5/19/23 9:39 a.m.
Thanks for the confirmation!  We're making a 1,600 mile round trip with this thing so having properly operating brakes was non-negotiable anyway.  I even ponied up the extra cash to replace the ABS computer and diodes to ensure that system is fully functional as well.  I remember Michael telling me that his dad always said something along the lines of not running is annoying, not stopping will kill ya.
dV1TGtSJMI5EN4xCrO2o0m7ZS9Ds32BgNBIbK2o6seiUQYzsk5zFBqFUyPhtlhk2
