Presented by Nine Lives Racing
gsettle
gsettle Reader
3/12/25 5:46 p.m.
I'm getting ready to build a Polycarbonate spoiler for Chaos (98 GMC Sonoma). The dimensions are 10" X ~55" X 1/4".
My plan is to mount the bottom side with SS piano hinge mounted to inside top of tailgate (so I can fold it down inside the bed when not in use) and use 4 turnbuckle stye splitter rods to support the top. Will this be strong enough?
Also, I plan to mount the turnbuckles to the tailgate with 3/16" pop-rivets as their shear strength is 310# according to Mcmaster Carr.
Anyone see issues with that plan?
Thanks in advance.
wvumtnbkr
wvumtnbkr GRM+ Memberand UltimaDork
3/12/25 6:52 p.m.
Thanks in advance.
Sounds great!
We did very similar for a bit in champcar.  No issues with it whatsoever.  Sounds like a solid plan.
gsettle
gsettle Reader
3/13/25 8:34 a.m.
Good to hear!
Any suggestions on spoiler angle? I've read they should be between 50 - 55 degrees...
wvumtnbkr
3/13/25 8:39 a.m.
gsettle said:
Good to hear!
From what I understand, it depends on what is in front of it.  Like if it is a flat area in front of it, you want a steeper angle versus say a sloping hatch.
It's adjustable though, so play with it and figure out what works best in your application!
stafford1500
3/13/25 9:37 a.m.
gsettle said:
Good to hear!
Since it is a truck and you did not specify if the bed is covered or not, here is my advice on angle:
Covered bed - run a straight edge or string from the top of the cab to the base of the spoiler and set the angle to about 90deg with the straight edge.
Open bed - run it nearly vertical, maybe closer to 10 degrees back from vertical.
gsettle
gsettle Reader
3/13/25 12:20 p.m.
stafford1500 said:
gsettle said:
Good to hear!
Awesome! Thanks for that info!
I'll post a picture of the truck when it's back on the ground and with said spoiler and front splitter installed.
pRvvcObrvJ0RhEcpWLwXbYrLrbiQrf9sVCr1SwoUDTcwItMxSkGemkcVkzToHhbd
