After seeing Downey do the same, I finally got around to building a passenger-side motor mount arm. This is a weak point on swapped e30s and stock e36s, the arm just isn't strong enough to support the engine weight under heavy abuse. There are a couple VERY expensive options on the market in Europe, but not trying to spend $200 for a motor mount arm.
So, out comes the scrap metal. Specifically some 8mm bar and some heavy plate.
One of the other things to do here is to make the mount plate to the block go to SIX bolt points rather than the original four. The block has two more empty mount points aligned with the other two, which is convenient. So first I took some plate (two 6x6 pieces, one of them already cut up a bit) and welded them together to get a roughly 6x9 piece.
Then took some bar to use as the "ear" to mount to the motor mount. I doubled up some of the bar stock to make what should be a very strong flat piece. Then bolted the bar into place on the motor mount and the plate onto the block and cut a couple arms to attach them together.
One that was tacked up I took it off the engine and welded it up on the bench. Halfway through I ran out of welding gas so had to switch to flux-core, which makes everything less pretty....
Meanwhile, walked outside to do something and forgot my phone so turned around quick and promply smashed my nose into the garage door, which I hadn't opened all the way. After 5 minutes of being dizzy and blood flowing down my nose, got that all patched up. Good thing I wear a mask when out and about, which will cover this lovely band-aid
Anyhow, then I triangulated the piece and made an upper brace bar and some other braces here and there.
And here's what it looks like vs. the stock piece.
test fit
then painted it up and installed fully
So, hopefully that will be sufficiently strong. I thought about boxing it all with some thinner plate, but that would have made it difficult to access all six bolts to the block. Anyhow, I think this will be ok as-is, if not terribly pretty.
AFTER finishing, I recalled that I bought a plasma cutter a couple months ago which would have made this easier (and better looking). Oh well, next time...
