1 ... 158 159 160 161
NOHOME
NOHOME MegaDork
3/9/25 1:13 p.m.
In reply to Dusterbd13 :
Same here. More than a few people have wondered what that little polished piece of steel might be from.
tuna55
tuna55 MegaDork
3/9/25 5:18 p.m.
Dusterbd13 said:
Self fusing silicone tape or the split braided loom is what I typically use. Looks right underhood for the era as well.
Im soo glad to see where the truck is at these days. I still have a chunk of your leaf spring on my desk.
I'm glad that momento is still with you!
tuna55
tuna55 MegaDork
3/9/25 5:19 p.m.
Very cool
tuna55
tuna55 MegaDork
3/9/25 5:22 p.m.
lnlogauge said:
In reply to tuna55 :
If you can't find what you want for a battery cover, it sounds like a fun 3d printing project. I'd be happy to print one out for you. Username @ gmail, give me some dimensions and a pic of what you want it to look like.
That sounds like a neat idea. Let me think a little. I'm appreciate the offer!
tuna55
tuna55 MegaDork
3/9/25 5:29 p.m.
tuna55
tuna55 MegaDork
3/29/25 7:30 p.m.
Headlights work, taillights work, brake lights work, left turn signals work, horn works, dome light works, windshield wipers work. Aligned shifter arms.
Still working on right signals and reverse lights.
I think I have room under hood for a tunnel ram. Anyone getting rid of a 400 or aftermarket small block that I can make bigger? How about a posi for a truck 12 bolt?
tuna55
tuna55 MegaDork
3/29/25 9:53 p.m.
Minor update. Both signals and emergency flashers work. Reverse lights are a mystery. Also apparently I never finished fuel line vent properly  oops.
tuna55
tuna55 MegaDork
3/29/25 9:59 p.m.
Okay I figured out the reverse lights. I need to procure the other end of the switch on the transmission.
I didn't mention this earlier but the side window and vent window are also in on the driver side.
Dusterbd13
Dusterbd13 MegaDork
3/30/25 5:39 a.m.
I know I've seen your generation of truck with a roots blower under an unmodified hood. Don't know ive ever seen a tunnel ram though.
tuna55
tuna55 MegaDork
3/30/25 8:09 a.m.
I drove it around the yard and a tiny bit of my street last week. It's only going to be fun to drive with 500 horsepower. It needs a big small block with a tunnel ram making a big broad flat torque curve, and it needs to idle like Alex playing Hot For Teacher.
NOHOME
NOHOME MegaDork
3/30/25 8:57 a.m.
I know you don't want to hear this, cause you have said so...but the funnest result you are going to get is a Gen 3 or 4 Vortec  6 liter with an auto box, preferably a 4l80. ( 5.3 will also do the job just fine)  Find a drive-train from a vehicle that drove to the scene of the accident and harvest the whole enchilada of drive-train components for $2000-$3000 and it will bolt in with little effort. Cam swap and you are done; full cam kits are around $500 and up.  Don't even need to take the heads off to swap cam and get near your 500 hp.Take the full AC system while you are there cause chicks dig AC more than burnouts. VATS removal can be free with software you download on line.
Cammed, tunnel rammed, high-compression small blocks are not fun to drive on the street and are going to get sub-10 mpg. You will never want to go on a long trip that involves a HWY.
But I digress and you don't need me preaching at you from the pews of the converted. Get the truck on the road and spend the next year or two getting the chassis sorted. That will give you a much better idea of how you want to improve things.
Attaching a clip of the latest build that I have been involved with and this was done for like $2k Cnd over a few months time.
tuna55
tuna55 MegaDork
3/30/25 9:21 a.m.
In reply to NOHOME :
It's not that I don't want to hear it, it's that it's not helpful. There's no way in the world that's happening. It may just be that fun means different things to different people.
CJ
CJ GRM+ Memberand Dork
3/30/25 6:07 p.m.
Don't know how wonderful these are, but for around $20, they might be worth a look.  They have a Group 24 option and an Odyssey Group 34 AGM battery
https://www.tartopper.com/product/tartopper/
or the Delco alternative - https://www.ebay.com/itm/151044182004?_trksid=p4375194.c101949.m162918
tuna55
tuna55 MegaDork
3/30/25 9:12 p.m.
In reply to CJ :
I saw that.
I can't decide if this, coupled with a light battery, is a good choice (which would still necessitate a box, since the lightweight battery is much smaller) or if it's better to relocate the battery under the passenger side frame rail.
Dusterbd13
Dusterbd13 MegaDork
3/30/25 9:42 p.m.
Big inch small block, or massive torque caddy engine? What about something like a 472 or a 500? 526 ft-lb out of the box, 60lb heavier than what you have..  .
Probably not what you want, but it sounds like fun to me. Lately I've been craving unholy torque in something light, with supreme drivability.
tuna55
tuna55 MegaDork
3/31/25 9:34 a.m.
I think it stays small block with a tunnel ram unless I trip and fall over a big bore Gen III. I want it to be a 400.
SkinnyG
SkinnyG PowerDork
3/31/25 10:29 a.m.
Horsepower is fun and all....
The hand waves, thumbs up, and constant conversation at every gas station and parkinglot, are more fun with a truck like this than more horsepower.
tuna55
tuna55 MegaDork
3/31/25 2:07 p.m.
How I learned to stop worrying and love the truck; or more power
I'm not going to do anything stupid like take the engine out for a third time before the truck drives. I'm a windshield, a reverse light switch, a passenger side vent window, some gauges, a painted grill and front and rear bumper, a fuel level sender, a rollover valve, wheels and tires,a painted glovebox door and door panels away from being "done". I'll drive it like that.
But then it's getting a nice engine and a posi almost immediately. I can build it off to the side and plop it in in an afternoon.
tuna55
tuna55 MegaDork
4/13/25 8:20 p.m.
Some stuff getting done regardless of sparse updates. I have a ridiculous schedule.
Both door windows and vent windows are in now. I had a very helpful guy from the 67-72 truck Facebook group give me a bracket for the vent window.
I needed to weld it on because the holes in my frame were too large. Not sure if it was me from long ago or someone else. Either way I got to use my new welding hood. I welded a bit a work, and had to hand off my welder to another colleague, but he passed on my hood. After trying his I realized why. Mine was terrible, could barely see through it. I spent the money. It feels like cheating.
Anyway I have to buy a few expensive things now. Paint for the steering wheel, bumper and grill. Gauges. Wheels and tires. Coming soon, among braces, June trip, kids activities, etc.
tuna55
tuna55 MegaDork
4/17/25 8:57 a.m.
Current decisions I am waffling over:
I want to stay with the 3 gauge panel. Speedo, Tach and quad. Which one goes where? What color from Speedhut? I think speedo left, tach right and quad center.
What color should the gauge panel be? Black or yellow?
What color should the steering wheel be? Black or yellow?
What color should the bumper be? Satin gunmetal or white?
What color should the grill be? Satin gunmetal or white?
What color should the GMC field be on the tailgate, body color or white? If white, should it be vinyl or paint?
What color should the headlight surround panels be? Satin gunmetal or white?
What color should the door panels be? Yellow or white?
What color should the seat belts be?
Dusterbd13
Dusterbd13 MegaDork
4/17/25 9:00 a.m.
Blackface speedhut, speedometer center. Get the warning lights built into the quad. This is what I did on the duster, and im still extremely happy 10 years later.
tuna55
tuna55 MegaDork
4/17/25 10:02 a.m.
I think the speedo has to be left or right, and GM put it left.
Also I'm definitely thinking white face gauges
budget_bandit
budget_bandit HalfDork
4/17/25 10:45 a.m.
My Trans Am has speedo left, tach right and i'm partial to that arrangement
xflowgolf (Forum Supporter)
xflowgolf (Forum Supporter) SuperDork
4/17/25 1:12 p.m.
haven't checked in here in awhile, but just wanted to say awesome that this thing is so close to being "done" (at least for this round).
Major props to the tenacity to stick with this bit by bit.
tuna55
tuna55 MegaDork
4/17/25 2:01 p.m.
In reply to xflowgolf (Forum Supporter) :
Thanks!
It hurt a bit when Duster replied a minute ago about his Duster project ten years ago, because my build thread for this truck had already started then.
A few big decisions to make, but they are all pretty easily changeable after the fact.
MWnJrwUfL0WVzZgN96xCx8YvlRRjwvH0kPNEcxv99nZDXhFk174wITLI5kCmGLwm
