Day one went okay. Not great but okay. I knew there was some work to be done to get the rear brakes set up since I'm switching to 911 parking brake implements. This is required when ditching 914 calipers since they have a built in cable operated parking brake. I can't afford larger bore 914/6 calipers, so the 911 calipers are put in place to get the proper brake balance.
First thing first is to fit the backing plate of the 911 parking brake. In order to do that I need to pull the hub flange. A little hammering and the hub is free.
While I was there I wanted to replace the wheel bearing so out it came.
I needed to cut off the dust shield tab as well as grind more room for the backing plate to slide flush. You can see the tab in the pic above.
Now the backing plate slides in place and can be bolted up. To keep the shoes from spinning when the cable is pulled there must be a stop welded to the arm. I bought a full conversion kit from Tangering Racing so I didn't have to do guess work. The instructions weren't the best but I managed.
Here's the stop and where it needs to be.
Now welded in place. Still not a fan of this welder set up on MIG. I feel like I could lay good beads all day with flux core but just suck getting things to flow correctly. Oh well. It's glued in place and isn't going anywhere even if it's hideous.
Backing plate now installed.
Next up is cutting off the old parking cable bracket so it can be reloctated.
Then cleaned up and welded in place along with the cable adapter from Tangering Racing. Now the factory cable can pull the cable you see here for the parking brake.
The new bearing was installed, but pretty sure I borked that up. I used my hub bearing tool but didn't realized I wasn't supporting the center section of the bearing when pressing the hub back in. I guess we will see if it sounds like trash when it's road bound but will do better on the passenger side.
Just like the fronts, the caliper didn't center in the rear but my washers are too thick, so I'll need to get some thinner ones.
To wrap things up, I bent, cut, and flared the new hard line to the new soft line.
I need to see what Tangerine recommends to connect the two cables as the stock pivot pin is too large. I imagine a small bolt will do the trick.
Tomorrow I'll tackle the passenger side in hopefully less time now that I know what to do.
