The piston coating people called today to say they e-billed me a week ago and wondered if I planned to pay.....hmmm...no email but I do very much want the piston back. Billing person was gone for the day when I got the message and called back so I'll take care of it Monday I guess.
I haven't really worked on the CAN stuff for the steering. I played a little and I only see 1 message coming from the dongle thingy. I think I can set up the reading software to transmit so I can try a few things on the laptop before trying to code anything into the ECU.
I've decided to have a go at a push to start setup. The inexpensive setups on amazon appear to be not very useful....I can't be sure because there are no description of function for most of them but I decided to not bother figuring even if it actually is what I wanted I'm not sure I trust it to not leave me stranded. Probably the nicest option is to just put a latching on/off push button where the key was and let the ECU handle the starter.....and I may still do that at some point but I'm feeling KISS is the answer so I'll leave the ECU out of it for now.
I ordered a momentary push switch, 2 actually because the one I like I'm not certain is a momentary switch so I ordered a back-up that for sure is.
Then I ordered a 12v push button self-locking relay. This will go to ignition. push the button, ignition on, push again ignition off.
For the starter I orders dual standard 12V relays. One will be triggered by the brake pedal, 1 by the dash button.
so, $53 (but $10 back if I return whichever switch I don't use so $43) and if I've thought this through correctly it will function like this:
push = ignition on, push again = ignition off, no brake no start just ignition on/off
push and hold the brake + push and hold the button = ignition on and starter cranking, release brake or button starter stops but ignition remains on.
So not TRULY push to start because you need to hold the button for the starter but mostly. I'm a little concerned about turning off....I usually pull in, hold brake and clutch, engine off and that would cause the started to try to engage for as long as the button is held. I might add a timer, pretty sure I have one up stair on the shelf or learn to set the parking brake so I can release the brake pedal :lol:
it also leaves me with no actual key or locking anything preventing theft so that is something
Totally unrelated there the rear window defrosted switch had been broken I think since I've owned the car. I found a used one for $250 and did not buy it, which is why I never fixed it. My 1st car was a very sad 1966 austin healey 3000mk3 (which is where my user name mke - mark E kind of like 3 comes from and I thought it funny the same way I chuckle every time I initial anything "me") and I would swear the overdrive switch looks like the ferrari switched so I bought 1 on ebay for $20, the lever is wrong so I'm betting the $20 I can pull it off and slip on the ferrari lever and once again have a working switch sitting in the console designed for no useful purpose but perhaps if I think really hard I can come up with something.
