mke said:
In reply to DaewooOfDeath :
I've designed exactly 1 suspension so suggest away :)
Sitting in my amazon cart waiting for me to get the engine back together and need it is scale....I would love to know what this engine weights. I'm the k24 guys numbers are right...but also wrong. I have no doubt he measured what he measured, those numbers look similar to what others found, so they are right. They are also a bit wrong in that as you race prep older ferrari stuff weight comes off...I'm pretty sure race weight on a 308 engine/trans is about 650, still a big number but its a 50 year old design, it was good in its day. The V12 is very litterally the V8 with 4 more cylinders....the TR heads will drop onto a 308 block....port angle differences but they are the same, boxer pistons fit 2v 308s, TR pistons fit 4v 308s. The 60 degree v12 block is an older design (which I learned the hard way when I discovered the head stud locations are a little different) but they use the same connecting rods, bearings, cam sizes....so small changes. All that said I expect the eng/trans with everything I've done to weight about 800lbs, I'll be sad if its 1000 but that is certainly a possibility....but I'll get that number before the engine goes back in the car.
Installed the trans is sitting 1/4" higher that stock....it was that or notch the already soft frame to clear the flywheel. The engines crank though sits 2" lower and 3" forward of the the V8s so even with the added height of 60deg vs 90 and added weight 12 v 8, I'm pretty sure new mass center is lower and f/r split similar to stock or at least to the V8 with big supercharger that came out....but what to do suspension wise has been on my mind since I first bolted the 80 or 100 lbs of blower parts onto the top or the V8 and I'm clearly still undecided.
New rear springs arrived yesterday, 8" to replace 10"
Siting with the adjusters full up so rear as low as possible here it is
Last time when I measured the front I was looking at the valance and getting about 4.5". last night I laid down on the floor and discovered 4.5" at the valance is about 3.25" at the frame so the front goes plenty low. Right now the frame in the back is at 4.5" with no engine. If the engine is 1000lbs with exhaust and everything and the spring 500lb/in each and nearly 1:1 motion ratio the rear will be 3.5" full low so I guess it works out as this might work at an autocross but is too low for street use.
I can rise it about 2" which would be just about stock or perhaps a touch over so these springs seem good length wise.
The suspension design I've done has been basically to copy Steve Hoelscher's MR2/X19 autocross cars and then correct for weight distribution. https://www.mr2oc.com/threads/sts2-mk1-suspension-setup-w-host-xhead.298272/
Some disclaimers compared to what Steve wrote:
1. This sort of car will ride pretty rough for the street. I'm a crazy person, so this was no problem for me, but you might feel differently. I ran these setups basically backwards from Steve's cars. I was using FF cars, Steve was using MR cars and my logic was that a FF car driving in reverse is basically an X19 (or Ferrari 308). This meant that my ride frequency was much higher in the back of the car than in the front, which didn't matter much for handling but does tend to feel harsher on the street than having higher frequency in the front, which is how you'd end up tuning. In other words, even if you copy exactly what I did and run in backwards, it should be less harsh than what I had, and what I had was harsh but tolerable.
2. I think I was running higher relative roll centers than Steve did. I tried lowering the car to approximate what he had and, while it might have been faster, I thought the high roll centers felt better. For my FF stuff, I got the best driving experience with the rear roll center roughly 12 inches off the ground and the front roll center about 7 inches off the ground. Higher than that caused jacking in the rear, lower than that created too much roll in the front. Since you are working on a MR car, you'd basically run everything I did backwards.
3. It's incredible how quickly a truly independent (ie, no anti-roll bars) setup reacts and deals with small bumps. I KILLED people in long, bumpy corners with Hoelscher's setup.
