ultraclyde
ultraclyde PowerDork
12/10/18 10:13 a.m.
Lookin good. Did you do the headliner yourself? I need to do that on the ZJ at some point. The edges are sagging but the center isn't so I can put it off for a while. Also, what cheap mudflaps are you using?
bOttOmfeeder
bOttOmfeeder New Reader
12/10/18 1:46 p.m.
I bought the headliner material on Amazon.  Peeled off the old material and spray mounted the new material on.   I recommend rolling over the front lip.  The other edges are covered by molding.  We trimmed the material off leaving an exposed edge and there are spots I wish I rolled it.  Pretty easy job, just messy.
I bought enough material to wrap the visors too.  The visors have a plastic frame, but several of the snaps didn't relock well. I used a glue gun to hold the frame together.
I bought the basic Rally Armor mud flaps and use large head rivets and two 1/4" bolt/washers/nut with a rubber hose spacer.  The fronts are mounted well, the rear doesn't have a good place the attach the insides.  I may trim some of that material away, but the flap is pretty stiff.
Pat V
VQmsEmfO79pTKEMboiMPoK9Uto3wlDh7HL3yVYnIPSGUnEVgFIuvVP9tI8BzTqr0
