1 ... 13 14 15 16 17 ... 33
Dusterbd13
Dusterbd13 MegaDork
3/21/18 6:32 a.m.
Thinking more after last night, step one is centering the axle step two is notches. Step 3 is everything else.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 1:42 p.m.
step one is nor replacing the bent axle. Found why it wasn't square and the rear brajes never stayed in adjustment.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
3/21/18 1:43 p.m.
That'll do it.
pres589
pres589 PowerDork
3/21/18 1:57 p.m.
Is there a drop-in five bolt axle that has discs that you could swap in that's also up to the task of doing truck stuff?  I can't think of one off the top of my head...
Dusterbd13
Dusterbd13 MegaDork
3/21/18 1:59 p.m.
Also, since I'm in this deep already, I'm going to go ahead and read Notch and box the frame. It will always bug me if I don't.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 2:01 p.m.
In reply to pres589 :
8.8 is the closest i can think of.  However, local yard has a warranty on a 3.42 geared stock replacement rear delivered to my shop for $250. Im hitting the easy button.
pres589
pres589 PowerDork
3/21/18 2:14 p.m.
Absolutely nothing wrong with the easy button in this case.  Maybe at some point down the road you could swap on discs to the stock replacement if you really hate dealing with the drums that much.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 2:19 p.m.
Im hoping that when everything is back in spec and rebuilt that the drums work as intended.
Salvage yard called a minute ago and said that they may have the rear ready tonight yet.
Unfortunately I put the pressure washer away, since i thought i was done. Oh well.
John Welsh
John Welsh Mod Squad
3/21/18 2:24 p.m.
I guess that rear tire took more impact than originally thought
Dusterbd13
Dusterbd13 MegaDork
3/21/18 2:36 p.m.
Agreed! Jeremy had replaced the axle shaft as the hub face was bent. I saw no other obvious signs until today.  Musta been a helluva hit.
Patrick
3/21/18 3:49 p.m.
Damnit, there’s an axle behind my garage
Dusterbd13
Dusterbd13 MegaDork
3/21/18 4:04 p.m.
Well crap. I do think it would be more in fuel and lodging than the local one though.
SaltyDog
SaltyDog Reader
3/21/18 4:13 p.m.
Did you confirm it's the housing that's bent and not just the backing plate?
Dusterbd13
Dusterbd13 MegaDork
3/21/18 4:23 p.m.
In reply to SaltyDog :
Best as i could. Seems to be tweaked about 1/16 from flange of brake backing plate to leaf spring pad towards the rear. Making that wheel toed out. Measured toe out of 3/8 as well on the rear axle. So im fairly certain that its bent.
SaltyDog
SaltyDog Reader
3/21/18 4:33 p.m.
Yup, sure sounds that way. Dagnabit.
Dirtydog
Dirtydog GRM+ Memberand HalfDork
3/21/18 4:40 p.m.
Dirtydog
3/21/18 5:05 p.m.
Thinking about it.  Hit the easy button. Why make more work for yourself.  Time vs money.  Plenty to do elsewhere. Besides, working brakes, and suspension are nice.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 5:59 p.m.
Yup. Easy button. Swap the rear (wasn't ready tonight) after a quick clean and paint. Change the fluid, build the brakes, be done. Easy button.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 6:06 p.m.
That escalated quickly.
Like 2.5 hours quickly.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 6:11 p.m.
And to those of you reading this:
You guys doing parking lot builds, working in single car garages, outside in the dirt, etc: my hats off to you. You guys have BALLS. this stuff is tough enough in a climate controlled, well lit space with all sorts of tools. But you guys go to another level. Thank you all for inspiring me.
Stefan
3/21/18 6:28 p.m.
Maybe arrange to have the spare from Patrick arrive if the drums don't work out so you can rebuild it with discs, LSD, etc. for a quick and easy swap.
Dusterbd13
Dusterbd13 MegaDork
3/21/18 6:34 p.m.
That's a pretty good idea!
759NRNG
759NRNG SuperDork
3/21/18 6:37 p.m.
Bro.....I  woulda chimed in earlier ,but life has gotten in the way (stayin' in D'Iberville Ms. workin in Mobile Al. first job i've  had in 2.5 yrs). This speaks to me.....I've done the lowered front lCA's and the dearched rear leaf's.....and someday soon the SSBT full on brake swap will occur (13'sfront/11's rear$$$$), but my very favorite part of all this is the wokbowlTBI whoodathoughtit............effen brilliant!!!!!and to think i spent $$$  for the high zoot spun allomeum spacer......your resourcefulness speaks volumes!!!!wink
Patrick
3/21/18 6:42 p.m.
I have the lsd for him too
Dusterbd13
Dusterbd13 MegaDork
3/21/18 6:45 p.m.
Lets call it a posi. The term LSD does NOT bring back fond memories.
Is that assembly in your way?
And 759: it was 25 cents or so, and seemed perfect.  3 years later it finally is!
nvvgd4jyYIHgvfpzJkIabyRJrOHHSSPcwdXzmzL4aW6J8VZQ2YacsJtSvxgGsVmu
