What’s worse than fixing something on your car? Fixing something that you have fixed before.
Okay, maybe we replaced our 1984 Porsche 911 Carrera’s turn signal/high-beam switch a decade ago, but it went on the fritz soon after.
The problem this time? The high-beams were stuck in the on position, meaning that we weren’t making any friends with our Hellas.
Just a touch of finger pressure, however, would turn off the high-beams. Our solution for a while, we’re embarrassed to admit: Just drive around with a bit of finger pressure on the switch.
But that’s not a proper solution.
One proper fix: Simply replace the switch–again. Depending whether going factory Porsche or aftermarket, the part is available for about $200 to $400 from the likes of FCP Euro, Pelican Parts and Stoddard.
But, we figured, let’s first try to fix it. We found a few tutorials on the Pelican Parts forum, including one that stood out.
Here’s how we fixed the high-beam switch.
Step 1: Undo the battery and then remove the steering wheel and steering column plastic surround.
Step 2: After gaining access to the turn signal switch, slightly bend the high-beam contact to provide the necessary space. Needle nose pliers worked well here.
Step 3: Hook up the battery and test the system.
Step 4: Assuming a successful Step 3, button up everything and enjoy.
