The best coolers from Yeti: Tundra 65 Review
Yeti has been one of the Top Rated Coolers For Camping on the market and the production of the Tundra 65 keeps proving that the company is worthy of the hype. Things people like about this cooler are its excellent performance, intense durability, and ease of use. This review provides you with several main features of this product so that you can easily compare and decide.
Performance
The Tundra 65 is on the top list of high-performance coolers. It provides you with one of the most impressive insulation systems, which allows it to maintain a temperature of below 40º F for up to 6.5 days. This outstanding performance is the result of an integrated hinge and a freezer-quality gasket, which, together with the great design, help the cooler maintain cold temperatures for longer periods of time. In detail, the manufacturer made the Tundra not too wide but, rather, low and long so that one person can hold and carry it. The overall surface is not so large that the cold or heat will be lost but the volume inside is still sufficient for you to put in everything you want.
Preparation for the cooler
The way you prepare your cooler and the items inside it will determine the overall retention. It is recommended that you pre-cool the device and your frozen or cold items. The number 6.5 days, which we mentioned above, is the retention time without any of that preparation, which makes this result even more remarkable.
Durability
When it comes to durability, the Tundra 65 is one of the Best Cooler In The World. Overall, it is sturdy and employs many tricks to improve its stability during movement and usage. First, a textured lid is designed so that you can sit on the cooler as though it were a chair. Second, the rubber latches are quite thick and flexible.
A rubber gasket is a common feature of coolers on the market, though not many of them work as well as the Yeti. In general, no air or liquids leak from the inside.
If the cooler is placed in a high temperature for a long period of time, you may see that the lid bows moderately but this phenomenon disappears when the temperature drops. Yeti has conducted many tests to prove the excellent longevity of the Tundra 65, so don’t worry if you bring this cooler on a harsh trip.
Ease in use
No one wants to buy a cooler which is difficult to handle, especially on an outdoor trip where you always try to keep things tidy, simple, and handy. For the Tundra, you might need just a little bit of practice to be able to master it. Once you are used to the device, you can open it with only one hand. The lid is flexible so it can either stay open as long as you want or close quickly with a push. Interestingly, the hinge is designed so well that its angle does not need to be overextended to hold up the lid.
One thing you might not like about this product is its actual weight. Without any items inside, it could weigh 32 pounds, which makes it difficult to be carried by one person. However, one piece of good news is that this product features a dual handle set so that two people together can easily move it around.
Value
With its high performance, sheer usability, and long-lasting life, the Tundra, as expected, is quite expensive, at a cost of several hundred dollars. However, you may save money in the end because you won’t have to buy new coolers to replace it.
Conclusion
The Yeti Tundra 65 is one of the Top Rated Camping Coolers on the market as well as one of the most impressive coolers in terms of design and performance. Though many other brands may imitate one or several features of this excellent product, they will never achieve the greatest that Yeti has created.
