Woody
Woody GRM+ Memberand MegaDork
3/23/20 6:51 p.m.
So for purposes of clarification,
My Wheelbarrow Thread
really should have been Corona Timekiller 1, which would would then make
Corona Timekiller: Hanging Ramps in my Garage
   Corona Timekiller 2
And so now I present Corona Timekiller 3: Making a $100 Cup of Tea with a Rocket Stove.
I learned about Rocket Stoves a few years ago (maybe here) and I have wanted one ever since. This kind of seemed like a good time to pull the trigger on one, so after a little comparison shopping, I placed an order on eBay.
eBay link to my new Rocket Stove
About a week later, and following some very good communication with the seller, a very nicely made, and well packaged rocket stove arrived at my doorstep.
They are designed to burn just about any kind of combustible waste that you can scrape together. So I gathered up some assorted sticks and slightly larger scraps of wood from around The Estate.
Getting it to light took a little more effort than I had expected, but I don't think that my wood was very dry. With some judicious selection of super dry dead sticks, a little cardboard and a few breaths of supplemental air, it cranked right up. I also put a couple of pieces of wood in the vertical chimney to get the draft moving in the right direction.
My goal for the day was to boil water and make tea. I was a little overly optimistic at the volume of water that it could boil quickly at first, but after dumping a little off, we achieved a rolling boil in a relatively short period of time, thereby proving the concept.
Once this thing is up and running, it will burn just about anything. Small dry sticks are easiest, but I also supplemented it with half a handful of wood pellets at one point. I even burned the wet tea bag when I was done, and there was no sign of it during cleanup. The key is to avoid building up a lot of ash at the bottom, which would restrict the flow of fresh air to the fire.
Combustion is very efficient. I am sure that I could improve heating efficiency by stacking blocks around the vertical chimney to minimize heat loss and keep it all aimed at the cooking surface.
I am happy with my purchase, and I am confident that I can boil water, heat a can of soup, or even cook a steak on a skillet with this thing.
And...it's kind of fun. Two Thumbs Up!
captdownshift
captdownshift GRM+ Memberand UltimaDork
3/23/20 6:58 p.m.
I will send you to coordinates of the island that I will be seeking refuge at once mended. Bring that with you.
Woody
3/23/20 7:01 p.m.
In reply to captdownshift :
I will welcome you upon arrival.
wlkelley3
wlkelley3 UltraDork
3/23/20 7:02 p.m.
Corona virus time killer #4: Now that you have one, reverse engineer it and make one. cheekydevil
Woody
3/23/20 7:07 p.m.
I've been doing that in my head for about three years, but I finally decided to just spend $100 and have one mailed to me.
Brett_Murphy
Brett_Murphy GRM+ Memberand MegaDork
3/23/20 7:07 p.m.
Woody said: Getting it to light took a little more effort than I had expected
Firefighter unable to start fire, cites years of doing the opposite. News at eleven.
That's a nifty little device. I'd love to know how hot you can get it going- it might be decent for melting lead outside.
captdownshift
3/23/20 7:16 p.m.
In reply to Brett_Murphy :
I see where you're going with that, you're also invited to the island
Woody
3/23/20 7:32 p.m.
Data:
Woody
3/23/20 7:34 p.m.
Woody
3/23/20 7:35 p.m.
Cleanup:
Woody
3/23/20 7:37 p.m.
Airflow was a little better when I threw a scrap metal cover over the feed port. Some stoves come with a similar hinged cover.
Mndsm
Mndsm MegaDork
3/23/20 8:19 p.m.
So, for the dummies of the group (namely me) is this just a way to get a screaming hot stove? Does it have a specific purpose?
Teh E36 M3
Teh E36 M3 SuperDork
3/23/20 8:19 p.m.
I'm thinking a stainless J bend in 3" would do the job with a slight mod to the J. Tack a couple flats to the bottom and we are in action.
Dr. Hess
Dr. Hess MegaDork
3/23/20 8:33 p.m.
And here I just had delivered today 18 feet of 4" square 11 ga tubing.  Humm.
Woody
3/23/20 9:21 p.m.
You can cook stuff using very little fuel. Sticks and twigs.
Woody
3/23/20 9:31 p.m.
It sounds like you’re in business. Or at the very least, you can build a really big rocket stove.
bearmtnmartin
3/23/20 9:41 p.m.
When I was a kid I used to use the British army method of making hot drinks which was to fill a tuna can with sand and pour some lighter fuel over it. It will burn long enough to boil water or a can of soup.
octavious
octavious Dork
3/24/20 7:10 a.m.
@woody  what does it weigh?
pilotbraden
pilotbraden UltraDork
3/24/20 8:32 a.m.
Try running  birch bark in it. It ought to run extremely hot. Birch bark also has the very handy property  of lighting with a match while soaking wet.  At my cabin kerosene is called liquid birch bark
Brotus7
Brotus7 HalfDork
3/24/20 10:43 a.m.
Am I child, or should that stove be painted red?
Woody
3/24/20 10:52 a.m.
In reply to octavious :
I’m not near it right now, but I’m sure it’s less than ten pounds.
Toyman01
3/24/20 11:02 a.m.
A fireman fascinated by fire. Who'd have thunk it. laugh
I keep threatening to build one, but I have so much crap now it's not even funny. When the world ends I'm just going to have to get by with a regular fire.
Woody
3/24/20 11:09 a.m.
In reply to Toyman01 :
I’m actually fascinated by warm meals.
Toyman01
3/24/20 11:11 a.m.
In reply to Woody :
The best of both worlds!
californiamilleghia
californiamilleghia Dork
3/24/20 11:15 a.m.
Wheres the cad file ?
but there are some other ones on Amazon for much less but not as heavy duty as that one !
UTeASXTAyd0zlQcfyE5Z9oUtU60znn6ESA16MNqUTw7lBjcWDNGBOCVBmgNqStKt
