Lexus ISF 5.0 V8 with Xforce catback but 3.5" muffler delete quad tips at the flanged axleback. The hotdog/bottle resonators still there.
Considering a single Spintech Sportsman 3000 XLP (8 spin traps with packing) or RV 8000 (10 spintraps no packing) 2.5 dual in/out where the current bottle resonators are.
Conclusions from what I've experimented/experienced and read/heard
- Mufflers: Overall sound reduction but perhaps not much for actual DRONE. May change the exhaust note/frequency and exhaust scavenging characteristics depending on what is inside. i.e.) Chambered/spin traps/baffled str8 etc.
- Resonators: Do very minimal in over all sound and drone change. May change the exhaust note/frequency
- Drone tube/Quarterwave length tube: Has to be measured out quite accurately to affect a drone range i.e.) I've read of a owner that two 27" long at 1.75" piping got rid of much of the troublesome drone of the ISF low range. These tubes can possibly have steel wool packing before welding up.
- Helmholtz chamber: Affects wider drone range than a quarterwave tube and no need to be as accurate in dialing in measurements as a drone tube.
I still want very audible exterior note, currently with the 3.5" muffler deletes it's actually very pleasing on the ears with a distinct lumpy rumble and NO drone under regular cruising at any gear especially freeway. The problem is any time I am opening up the throttle lightly (extremely bad if left in D) it drones SUPER bad. My teeth closed I can feel the loud droning vibrations shaking and rattling my teeth causing my teeth to cause a buzzing drone of itself!
I fear the 3000 XLP maybe too quiet but still potentially have a light drone (ok) if a heavy drone and I add a helmholtz chamber or drone tube the car may then be way too quiet.
Perhaps I can leave the exhaust as is and maybe will add two helmholtz chambers and the two 1.75" drone pipes at 27" length?? On that note, I need to figure out where to be helmholtz canisters or just turn some old mufflers into some.
