Jerry
Jerry PowerDork
9/2/21 7:03 a.m.
Amazon showed me an ad for a foam gun from Chemical Guys that didn't require a pressure washer, but many reviews said the gun is cheap and leaks like crazy.  A link from there took me to an Adam's, but saw similar complaints.
Anyone using a foam gun that doesn't require a pressure washer that actually works?
ProDarwin
ProDarwin MegaDork
9/2/21 7:07 a.m.
This one?
https://www.amazon.com/gp/product/B00F5MCL14/
I have it and use it.  No leaking, no complaints.
mfennell
mfennell Reader
9/2/21 8:01 a.m.
That's a generic gun with Chemical Guys logos.  There are identical versions for 1/2 as much.
https://www.amazon.com/dp/B08BZ4D5YL/
Does not give me much confidence in the rest of the Chemical Guys product line.
Dusterbd13-michael
Dusterbd13-michael MegaDork
9/2/21 8:03 a.m.
How well do the foam guns actually work? Like, at removing bugs and all the crap that comes on a daily? As good as a hand wash?
Placemotorsports
Placemotorsports GRM+ Memberand HalfDork
9/2/21 8:10 a.m.
Foam guns work good to let the soap soak in but it doesn't clean your car for you.  You still need a wash mitt to clean the dirt off when it's really dirty.
pirate
pirate Dork
9/2/21 8:20 a.m.
I have a foam gun that I use with an electric pressure washer. I use it for washing our motorhome and cars. Just spraying the foam alone without scrubbing/ rubbing the surface will not get the surface clean. However the foam layer does loosen dirt/bugs etc. and I think makes it easier to wash. I especially like it on motorhome because I can foam large areas and wash with a long handled very soft boars hair brush. Goes much faster then constantly dipping in bucket along with reducing the abrasive dirty water. Your mileage may vary.
ProDarwin
ProDarwin MegaDork
9/2/21 8:21 a.m.
Yeah, foam gun is just a lazy man's way of applying soap.  Wet the car, then soak it with soap and it loosens stuff.  You still wash & rinse like normal.
ProDarwin
ProDarwin MegaDork
9/2/21 8:25 a.m.
That one pictured has plastic fittings and doesn't have the quick release between the 2 sections.
I thought about it before buying the Chemical Guys one, but I didn't want to give my $ to a E36 M3ty version, have it break, and be annoyed immediately afterward.  I understand there isn't a huge difference between them, but I do assume that with a "name" like that there is a little bit more product quality/quality control.
Jerry
Jerry PowerDork
9/2/21 9:50 a.m.
ProDarwin said:
This one?
That was the one, but a bundle of the gun and two products - soap and wax I think.  I recognize the first review saying "here's the o ring you need for everyone saying theirs leaks."
I was also curious how well they work without mechanical agitation (ie wash mitt). Hm.
Cactus
Cactus HalfDork
9/2/21 12:22 p.m.
mfennell
mfennell Reader
9/2/21 12:34 p.m.
Good catch. I think this one is identical: https://www.amazon.com/dp/B095C3FHJ8
I've had an equivalent for about 10 years.  It's fine.  I use it to soap up the cars and then also use a wash mitt with a bucket of soapy water.
Tom_Spangler (Forum Supporter) GRM+ Memberand PowerDork
9/2/21 1:11 p.m.
Eh. I have one and use it semi-regularly, but I'm still not convinced that it's anything more than an extra step. But the car looks cool when it's all foamed up:
EIYP10ZkfRcCwVB8vXgUB4BviHbzbl62Wn6C1yinb0azYo0K5WouAlrTGPic4Ylh
