Working with electricity can be scary, and scary jobs are often left untouched. Why face a potential trouble spot when you can tackle a more comfortable task?
Such was the case with the electrical system of our Triumph TR3 vintage race car. When we first wired it up, we combined a cut-down version of the stock harness with a …
te72
Reader
6/5/19 10:31 p.m.
This is perhaps the biggest, most unfamiliar task ahead of me. I'm looking forward to having a solid foundation of electrical knowledge, but I can't say I'm looking forward to the hours of homework to get it. Nature of the beast I suppose...
I'm hesitant to dive in though, because as it sits, my car is running and driving. I just know that there are pounds of unused wiring, relays, and switch boxes in there, and many, many features that are unused since the car is so far removed from stock. Needs to be done, but tackling that job means the car is off the road until the job is done to my satisfaction.
_
HalfDork
6/6/19 12:30 a.m.
Cool. I will say this, PROPERLY crimped crimp on connectors work really well. The problem is most people don’t buy the little terminator to make sure it’s done right. What I love most about using crimp on is that the wires can be disconnected for diagnostics, and you can even swap wires around if you need to get power from elsewhere, and do it at the track. As A technician, I can’t tell you how much I love easy access for diagnostics and versatility.
JoeyM
Mod Squad
6/6/19 12:48 a.m.
Good timing. I just bought stuff to wire the Datsun.
I’m gearing up to re-wire my TR6 project. I was planning to start with a complete kit from Painless, Ron Francis, or Advance Auto Wire.
I'm planning on completely rewiring the DMC when I have it torn apart to fix the frame... this looks nice, but also like it doesn't have enough circuits for a full car with things like HVAC to run on...
_
HalfDork
6/7/19 1:32 p.m.
You could expand this one or double up.
Side note- I see you guys still used crimp ons, but didn’t terminate them right. Those little plastic sheathes over the barrel prevent any contraption from producing a fine, cold welded crimp. The proper way is a naked connector with heat shrink over that area to prevent arcing
Repeat after me kids: “No! No! No!”
“Yes! Yes! Yes!”
