OldGray320i
OldGray320i Dork
10/11/17 10:03 p.m.
...have you guys ever had issues with the springs rubbing against the sleeve threads?
I was running a longer spring w/o a helper - when installed, and still on the jack stands, the spring made contact from the bottom perch to the top spring seat.
Following an auto-x, the car was making a groaning sound as I would enter and exit my driveway.  Up on jack stands, I noticed that on the drivers side rear I had some sleeve thread rubbed away (pass side rear was completely fine and normal) - and the spring was now a 1/2 below the top mount.
Has anyone had issues with GC sleeves and an "un-tendered" spring?
Both rear dampers also make a funny, grinding/dirt in it noise as you articulate the shafts - the guy from Koni said he's never heard that without seals being blown - no leaks on the dampers, though.
So, I may have a two-fer....
10/11/17 10:47 p.m.
It's pretty normal for those springs to go loose on full droop. And yes, if they don't seat properly they can rub. It's a much bigger problem with the Illumina application on the Miata than the Koni one due to the way the perches sit on the shock.
OldGray320i
OldGray320i Dork
10/12/17 11:01 a.m.
Would the condition cause issues with the damper shafts?  I can't see how, but neither am I an expert...
I can't honestly think of a time the car would have been anywhere close to full droop on the suspension, except maybe going in and out of my driveway (the Focus had such a stiff chassis, that coming up the curb would routinely lift a wheel).
Nick (Bo) Comstock
Nick (Bo) Comstock MegaDork
10/12/17 11:15 a.m.
Is this an issue that is specific to the Miata? I'm planning longer softer springs on the Civic which has GC coil overs and plan to experience full droop occasionally.
10/12/17 11:17 a.m.
It's not going to cause a problem with the shocks.
Full droop is going to happen slowly, as the weight of the wheel is fighting the damping. In and out of a driveway is a good time to do it, but more likely it didn't sit properly when it came off the jackstads.
OldGray320i
OldGray320i Dork
10/12/17 4:29 p.m.
It was all fine and dandy (i.e. quiet and smooth) after the initial install, and until after the auto-x - by several days - and the car wasn't on jack stands again until I took the Koni's off.
Unfortunately, I didn't inspect them right away; turns out that if they're stored flat, they can air bubble (something they did NOT do last time I stored them off the car incorrectly...).  So I cycled per Koni's directions, they were beautiful and quiet and smooth in operation, and I set them upright/vertical.   Playing around with them about half hour later, one of the rear dampers was sucking air again.
This is the second time I've had a strange anomaly with Koni's (actually, the third if you count two defective rear units I got when I first bought them...); the first time the suspected unit tested ok, so I put it back on the car.  Car was fine for quite a while, but I didn't like the spring rates.
I put some 400lb units on the front (first it was 450 - too much; then it was 425 - those were ok, but...), and man, I loved it.  Fantastic feel to them, didn't matter what road surface.
Then auto-x, and they felt crappy.  Re-adjusted my ride height, they were ok for a while; a week or two later, the cowl shake on roads that used to be gravy was just horrible.  Changed out to some known good dampers/springs, rides like a Cadillac.
Not sure what the h-e-double hockey sticks is going on.  Somewhere between GC sleeves getting ground down by springs and funky Koni's, I'm having quite the time of it.
Raze
Raze UltraDork
10/13/17 6:55 a.m.
I say the Konis are going bad, send em in for repair.
Our GCs don't have helpers on the Merkur and I have to help reseat them after a full droop session, but what you're describing I've only ever seen with leaking or worn shocks...
QZGDbNcoW4FeRenv0SNyhUiXGOqexhlKGQRsR0ZpKOmyT982jhubyXOIr1hg4Bwg
