[Editor's Note: This article originally appeared in the August 2014 issue of Grassroots Motorsports.]
Chemistry enhances our lives every day. It causes light bulbs to illuminate, OxiClean to whiten our whites, and Doritos to be delicious. It can also be used to fight rust, a popular adversary.
I've used both Evapo-Rust and POR-15 quite a few times over the years. My only beef with Evapo-Rust is that it takes a long time. Figure at least 12 hours submerged for anything that could be considered even a little "rusty." Even longer if it's quite rusty and pitted. Still impressive, in that you don't have to be grinding it, or blasting it or sanding it. Just "kerplunk" and forget it for a while as the Evapo-Rust does its thing.
Evapo-rust works via a process called "Chelation", where a mix of chemicals pulls a metal element out of an ionic bond, only here to then be replaced by another element that then drops said chemical out of the compound. What's exactly in it is obviously a trade secret, but the black is raw iron in suspension.
To this, I'd like to add Geoff Croker's video on rust treatment which I think should be made into a wall tapestry and put somewhere in view of any shop that uses metal. The goofy voice he sometimes takes is grating, but he shows what genuinely works best- my "rust treatments" have now almost entirely been pared down to several electrolysis baths, citric and oxalytic acids, and some samples of evapo-rust for things I cannot afford to have pitted.
no mention of electrolysis?
or was this simply advertorial.
In reply to 1988RedT2 :
I don't mind the wait on Evapo-rust. I have used it on bike and guitar parts, too. Set it and forget it. I think I dunked everything in a plastic container fished out of our recycling bin.
Yup. Recycle bin is my go-to for suitable containers. Works great for small items. Big stuff is more of a challenge.
For years, I have used Ospho, it is cheap and effective. It is surprising that Ospho was not listed here since it has been around for decades.
When applied to rusted surfaces, OSPHO causes iron oxide (rust) to chemically change to iron phosphate - an inert, hard substance that turns the metal black. Where rust is exceedingly heavy, two coats of OSPHO may be necessary to thoroughly penetrate and blacken the surface to be painted.
In reply to Scott Skillman :
Is Ospho the same as the so-called Rust Converter sold under a variety of brands? Sounds similar.
POR 15 is wild stuff. Wildly toxic, but also wildly effective.
I love how you brush it on like third-grade art class and it dries like shiny powdercoating.
pirate
HalfDork
5/17/21 8:03 p.m.
I'm surprised someone hasn't said "don't get it on your hootus" yet.
POR-15 is decent stuff, but I waffle on whether I'd put it in the rust fighting category. It prevents rust, sure. However, if I remember my chemistry, if you just slap it on over rust it doesn't do anything to actually convert the rust. It'll hit the top layer and stabilize that, but that's all.
As a tangent, I wish there were something that I could use like Evapo-Rust for aluminum.
oneway
New Reader
5/19/21 7:51 a.m.
EVAP-O-RUST has been an amazing component in my resurrection project of a 78 280Z. The best part besides that it works so well is the dunk it and not worry about it time slot. My work schedule and life priorities often interrupt the resurrection project and sometimes it may be several days later before I get back to that rusty component. After washing the parts I have been using a rust converter spray from TP TOOLS and then priming with KRYLON Rust Tough Primer then top coating with an appropriate color choice. The parts look great. Just wish I could squeeze the while car into the EVAP-O-RUST jug. I have also been using the TP TOOLS RUST COVER PAINT on the large areas-floor pans, valances, headlight buckets, etc and have been very pleased with the results so far. Thanks for the great info, John-Lugoff, SC.
aircooled said:
Mr_Asa said:
....As a tangent, I wish there were something that I could use like Evapo-Rust for aluminum.
Oven cleaner?
Never use oven cleaner on aluminum, it will damage it. NAPA sells a product in a spray bottle called aluminum brightener that works pretty well.
I can't believe that no one has mentioned the cheapest rust remover going, apple cider vinegar. I have used it, full strength, to clean parts, inside motorcycle gas tanks, old tools, etc. You can re-use it several times before it becomes too weak to effectively remove rust. It's biodegradable, and makes great salad dressing mixed with used motor oil.........that last part may or may not be true, I haven't tried it....yet.
P.S. Regular old white vinegar, to the best of my knowledge, does not work.
In reply to 300zxfreak :
I tried that on a heavily rusted small engine tank. Dumped some bolts in there, shook it around a few times, and let it sit for a while. It worked pretty well!
aircooled said:
Oven cleaner?
I'll use oven cleaner only if something is so greasy that I can scrape it off with a screw driver. Other than that it will eat aluminum if you let it sit on there.
But that's not quite what I meant. I'm looking more for something as gentle (or almost as gentle) as Evapo-Rust is on iron.
There's no real chemical difference between white vinegar and apple cider. Both are acetic acid at about 5% strength
In reply to Mr_Asa :
Not being a chemist, I can't debate what, if any, difference there may be. But, from experience I just know that regular old white vinegar just does not work as well, have no clue why, that's just the way it rolls.
tjbell
HalfDork
5/20/21 9:32 a.m.
Now what about on a frame? I just bought a cheap rusty gmt400 tahoe and the frame is pretty damn scaled in rust, no holes though. It's a rust belt car and I'm trying to find the best thing to use, so far rustoleum rust reformer looks good
How about a set of long tube headers? They have to be stripped to bare steel for painting.
Because it's not as cheap or as effective as powdered Citric acid dissolved in water- I got a 5lb bag of it for about $10 and a tablespoon makes a more potent acid than its equal weight in Vinegar.
