NOHOME
NOHOME UltimaDork
4/20/18 7:58 a.m.
After more fun than I care to repeat, I finally got the damping pads off the inside of the Molvo's roof panel so I can start to iron out that field of steel.
Before I can start, I need to figure out how to remove the residue of adhesive. It is still sticky enough that it would glue the tiles back on if I touch them back, and certainly a hindrance to the work I need to do.
Acetone did not do much to dissolve the stuff, made it soft for a while so I could wipe it around, but not lift it. Any other tricks I should be aware of before I go at this with a wire wheel in a less than ideal overhead position? Did I mention it sucked removing the things!?
Pete
4/20/18 8:16 a.m.
MEK.
stafford1500
stafford1500 GRM+ Memberand HalfDork
4/20/18 8:20 a.m.
Brand Names: Goof-Off or Goo-Gone
Add lots of shop rags and elbow grease...
NOHOME
NOHOME UltimaDork
4/20/18 8:21 a.m.
Methyl Ethyl Ketone?
Any hints on where a civilian would obtain such a chemical? Sounds like something I need to show up in a HazMat suit to collect.
stuart in mn
stuart in mn UltimaDork
4/20/18 8:33 a.m.
I'd try 3M general purpose adhesive cleaner.  It should be available at most auto parts stores.
https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-General-Purpose-Adhesive-Cleaner/?N=5002385+3293242391&rt=rud
stafford1500
4/20/18 8:37 a.m.
MEK is available in the big box hardware stores south of the border, maybe not on your side.
It has the side benefits of: smelling like butterscotch and directly attacking the reproductive bits...
4/20/18 8:52 a.m.
I have good success with rubber cement thinner.  My brand of choice is Bestine, but there are others.  It's a solvent, so it should be used in a well ventilated area, but it's not exceptionally lethal and it's fairly benign on paint and most plastics.
BESTINE
dculberson
dculberson UltimaDork
4/20/18 9:23 a.m.
In reply to Duke :
“not exceptionally lethal” — now there’s an endorsement!
Dirtydog
Dirtydog GRM+ Memberand HalfDork
4/20/18 10:10 a.m.
I have had success using plain old rubbing alcohol on glue residue.  Cheap and pretty effective.  Dries quick too.
lnlogauge
lnlogauge Reader
4/20/18 11:57 a.m.
Someone on here recommended bestine to me before.
Bless them.
It took the adhesive off remarkably well, and didn't harm the paint at all.
4/20/18 12:15 p.m.
In reply to lnlogauge :
That would probably be me. It’s one of the best-kept secrets so I like to share it as widely as possible.
Toebra
Toebra HalfDork
4/20/18 1:18 p.m.
WD40, goof off/goo-b-gone, lots of stuff you can use
E9lzXIHSVKrmY2PIlj9eyHSpkwtSsASdqqbAWbfFn6kflclGxwpb43EnEWGXfpwa
