codrus
codrus GRM+ Memberand Dork
12/14/15 4:56 p.m.
44Dwarf wrote: Don't use an abrasive wheel to cut hose. you end up with particles in the hose. Use a Blade type cutter. like these I use electrical tape as well.
Hm, do those really work for steel-braided hose?
For smaller hose I sometime use a cold chisel and a big-ass hammer to cut them instead.
44Dwarf
44Dwarf UltraDork
12/14/15 6:23 p.m.
Yup cut hundreds of -6 hose, + 50 or so -4 Teflon and still not a mark on them.
oldopelguy
oldopelguy SuperDork
12/14/15 6:45 p.m.
I use the same thing when I cut hose, also no issues. I actually use mine for all my hose cutting.
Electrical tape for me too, or shrink wrapping like you use around pallets. In my experience less sticky is better because it lets the strands stay where they are.
Dr. Hess
Dr. Hess MegaDork
12/14/15 7:49 p.m.
I use Harbor Freight cable cutters. The smaller ones on like up to -6 and the big 3' long ones on the bigger stuff. Finish off any remaining strands with wire cutters.
Dusterbd13
Dusterbd13 UberDork
12/14/15 8:53 p.m.
So I found that the traditional two piece ninety degree fitting (need 10) are 50% cheaper than the push lock version. The Russell two piece is the same price as the no name ebay push lock.
I had planned on running black nylon braided hose for looks.
You guys have been discussing the two piece version extensively.
Is there a good reason, on a street car, to run push lock vs the two piece?
motomoron
motomoron SuperDork
12/15/15 11:44 p.m.
I used the Earl's blue hose and push lock fittings for the fuel system on my race car. A little Earl's assembly lube and a heat gun and they go together easily. After everything is assembled and clocked I install an Oetiker clamp on every one. Very secure.
Datsun310Guy
Datsun310Guy PowerDork
12/16/15 7:08 a.m.
Correct. No -5 PL hose. Adapters....
Paul_VR6
Paul_VR6 Dork
12/16/15 11:59 a.m.
I have a bunch of -6an black stuff I am not going to use, email me what you need, I'll cut you a deal! kandpperformance at gmail dot com
Dusterbd13
Dusterbd13 UberDork
12/16/15 12:49 p.m.
I have a list at the house. I'll email you in the next couple hours.
Dusterbd13
Dusterbd13 UberDork
12/16/15 2:04 p.m.
In reply to Paul_VR6:
you have mail. let me know if you didn't get it.
1Ne8CcCH4yAm0xV5uTgajeyRGXUwUdepDuQagXWnrceTWLYAqEmWRLSehqyk16hr
