Floating Doc (Forum Supporter) GRM+ Memberand UltimaDork
1/22/23 9:24 p.m.
I have my NB1 up on jackstands due to an issue with the clutch hydraulics.
I then noticed that the starter has a crack. That looks like it won't last long.
Then I spotted this cracking around the oil pan drain plug. I think I've seen a discussion about this before, and that it was superficial and not uncommon.   Am I right, or do I need a new pan?
NOHOME
NOHOME MegaDork
1/22/23 10:05 p.m.
Pretty sure the spider web surface is normal.
aircooled
aircooled MegaDork
1/22/23 11:50 p.m.
Yeah, that looks pretty normal for cast aluminum.
Excellent picture of the bolt BTW, perfect focus and a bit of drama in the lighting!
1/22/23 11:56 p.m.
I also found out where my AC is leaking. Not good news either.
codrus (Forum Supporter)
1/23/23 12:31 a.m.
My starter did that, it was fine for several years.  I replaced it when I had the motor out for other reasons.
Mr_Asa
Mr_Asa GRM+ Memberand UltimaDork
1/23/23 7:28 p.m.
An oversimplification:
When you cast something, the aluminum can cool slightly when it hits the surface of the mold and form something akin to a skin.  The fluid pressure of the molten metal will press on that skin and bunch it up.  The webbing is basically that skin being bunched up and sitting against the surface.
Txx3DTzFNBKjzNze50okLCd7Qzv2YJ3geSzMcGrtEJuiVFIFmNt1PXeog8L5RQOL
