BALLS!
The motor that's in the car made 675hp to the wheels with a small GT30, and a log turbo manifold. With the new setup, it should make 800-900 hopefully.
Given the size of the car and the length of the header's pipes between the bends and the collector, I'd be more worried about tripping over the turbo when walking from the front of the car to the driver's door. The engine in a civic is on the "wrong side".
turboHLS30 wrote: Here's the infamous Civic, it's got some $$$ into it lol
That thing sucks, yo. Put some springz on dat bitch.
N Sperlo wrote:Osterkraut wrote:Should have piped in the conversation then. I believe the complaint was corrosion. I'll be taking care of that today. Believe it or not, I WOULD have appreciated your input.N Sperlo wrote: I just got my Pacesetter in the mail and you could convince me thats one of theirs.NOT a compliment.
What conversation was this?
turboHLS30 wrote:Osterkraut wrote:Oh ok lolN Sperlo wrote: I just got my Pacesetter in the mail and you could convince me thats one of theirs.NOT a compliment.
No no, Sperglordo meant it as a compliment.
Pacesetter's actually aren't very good, if you use good steel (321 would be nice) and clean welds yours will be better
iceracer wrote: I always understood that a long pipe was good for low end and a short pipe for high end.
Somewhat less important for turbos.
In NA headers you have two options: long tube, or short tube (or long primary/short primary). Longer versions of both move the power curve down the RPM range, reverse for shorter versions. It's generally accepted that long tube headers make more power, but you're looking at VERY long distances (RX-7 needs 90"+), so short tube headers (about 30" for RX-7s) are more common and still make good power.
akamcfly wrote: Given the size of the car and the length of the header's pipes between the bends and the collector, I'd be more worried about tripping over the turbo when walking from the front of the car to the driver's door. The engine in a civic is on the "wrong side".
Yeah, I was in a hurry so I just threw it together lol It will be shorted 10"-20"
Gimp wrote:turboHLS30 wrote: Here's the infamous Civic, it's got some $$$ into it lolThat thing sucks, yo. Put some springz on dat bitch.
LOL No need to worry about that, it's got K-Sport coilovers now. As you see it in the pics it ran 11.8 with stock suspension and some slicks.
not sure you want the merges to collector with flat sides.
Hmmm, is there a bit of room to re-shape pipe #4? Add a gradual curve in the 2nd section to get the pipe running more parallel under the other pipes, that way instead of one 120 degree bend down low, you can do a similar thing with 1 45, and 1 90 degree bends, and while doing it make pipe 4 longer to math the other pipes more closely in length
