Vigo wrote:
Just to clarify, as you took my brakes portion out of context, that I stated that the brakes will fail after being mis-applied by the driver by pulsing them on and off for miles thus boiling the fluid, etc.
How many MILES of pulsing does it take before we declare this person a lost cause? Still not the brakes' fault.
I never said it was the brakes fault. Please stop assuming things or putting words into my mouth. It's pretty well known that abused brakes, used improperly, will fail. Just like any other mechanical or electrical item.
Vigo wrote:
Also, on the Neutral bit, I totally agree but please again be aware that we are not talking K-Cars here.
Drrrp drrp. Are we also not talking the hundreds of different models ive worked on as an ASE master tech? Gimme a berkeleying break, with that comment.
Oh E36 M3 im in drive and at WOT!!! WHAT DO I DO!!??!
PUSH FORWARD. Thats it. Dont look. Dont jiggle it in random directions. Push forward. AMAZING!
Im not generally a pro-business and berkeley the proles kind of person, but it is seriously mis-guided to try to force manufacturers to make it their job to defeat darwinism by dumbing down their products to be safe for our dumbest few.
Wow. You have totally just showed your complete and utter ignorance of just how berkeleyed car controls have become in the last 5 years. Examples:
Toyota Prius Gen2 (one of the recalled cars):
You have to go up & right simultaneously, then left. It's also 100% electronic and the computer will lock you out of neutral above a certain threshold (I don't know the exact MPH).
Jaguar XJ shifter:
Note that the control wheel pops down flush with the console when you are moving. So when your car is running away, you have to figure out how to get that adjustment wheel up, then move it N, and hope the electrons will actually allow the trans to do it's job.
Jaguar XF is the same way:
Ferrari 458 Italia:
Can you even figure that one out? Some of the flappies make you pull back on both paddles, others have a button buried in the center console, like on the F430:
Sometimes the stuff is just designed into complete idiocy, like this 2011 Lexus LS shifter:
Notice how the N and the + are both printed next to each other on the panel? So where is N on the gate? The top of the far left track or one of the dog-legs? Now figure it out while coping with an emergency situation and trying not to hit anything.
Try Mercedes S-Class:
Are you going to signal a left turn with it, break it off, or get it into neutral?
Speaking of, check out the last-gen 7-series BMW shifter:
So is Neutral the up or down arrow? Both?
It's okay though, the new generation fixed it:
It doesn't even have gates! You just have to figure out where in the electrons it's supposed to be, the whole shifter just kind of flops about.
The Volt's shifter actually hides in the console. Check out GM's completely idiotic pre-production idea versus the still criminally insane production version:
Hell, your teenager ought to be able to figure out the Leaf's, it's just a mouse!
So, as you can clearly see, modern shifters are not all sunshine-and-gravy easy like you claimed, and even a non-derpping person can struggle with them. You still totally ignored the fact that many shifters are 100% electronic and will not shift the transmission into neutral, even if you do get it right. So please step off of your horse and join the rest of us in sensible-land.
