Tim Suddard
Tim Suddard Publisher
1/4/23 8:37 a.m.
At our first track day in our Porsche 997, we began to run out of brakes. Despite Porsche’s reputation for superior stopping performance, the FIRM can be a tough opponent. Blame the mix of tight turns and relatively short straights.
[The Grassroots Motorsports ultimate guide to track car lap times]
Before going back, we’d need to replace our stock, …
Andy Hollis
Andy Hollis
1/4/23 9:35 a.m.
Drilled rotors?  Really?  You like stress risers and cracks?
Tom Suddard
1/4/23 9:51 a.m.
Welcome to the thrill of Porsche ownership! Tim's a restorer at heart, and just couldn't bring himself to put the wrong rotors on the car. It's been interesting watching him balance the desire to keep this car original and perfect with his desire to thrash it on track.
Olemiss540
Olemiss540 HalfDork
1/4/23 11:19 a.m.
Cheap Chinese rockauto blank rotors ftw!
fusion66
fusion66 Reader
1/4/23 11:45 a.m.
No worries...I expect the Hawk HP+ pads will have significant fade before reaching very high temperatures  and thus not thermally crack the rotors wink
codrus (Forum Supporter)
1/4/23 12:22 p.m.
Yeah, I tried HP+ once and decided they were the worst of both worlds.  All the noise and dust of a true race pad, but none of the high temp capacity... :)
JG Pasterjak
1/4/23 1:03 p.m.
I have pretty limited experience with these pads on track on this car, and it was under less than ideal conditions, but I can say they have really good initial bite for a pad that can also get you to and from the track. But, yeah, they're messy.
I'm actually a big fan of Hawk's Street/Race compound, which we used on the S197 Mustang project. They're also filthy, as most Hawk pads are, but they make up for it my being a pad that excels at both low and high-speed competition, so long as you aren't running tons of laps back to back.
I'm curious to see what kind of rotor wear Tim gets from the HP+. That's really the rub with any truly good pad, is how quick do they grind up the rotors. If these can sustain the rotors, while providing enough capacity for the few track laps he's even going to need them for, maybe the dirt is worth putting up with.
Error404
Error404 HalfDork
1/4/23 1:29 p.m.
HP+ won't eat rotors in a few trackdays but you may find sessions at The FIRM limited by brake fade. I like HP+ as a good pad for someone who just caught the bug, bought a CAI and some pads and is going back. For serious work, Hawk DTC and Carbotech have much better temp range. HPS is a good DD pad, better modulation and bite than parts store pads for not that much more, in the grand scheme that is.
deaconblue
deaconblue New Reader
1/4/23 1:39 p.m.
I have tried to use the Hawk HP + before as a one and done dual purpose use pads.  But they are simply too noisy and way too freaking dirty for street use and not capable truly enough on the road course either. Basically had to "late brake" to make them work right and minimize the grinding noise on the street and would still got lots of disapproving looks at intersections.  I would consider them as an autocross use pad.  I have used the Hawk HPS pads for my toy's street driving and on most of the daily drivers. In the past I would typically switch out the toy's pads to Hawk Blue front and Hawk Black in the rear or (Carbotech XP-10 front and XP-08 rear) for road course duty.  I am sure there are newer pad materials now that maybe better.
BTW, what are those crazy, what appears to be ceramic rollers for on the stock pads?!?
dps214
dps214 Dork
1/4/23 1:49 p.m.
Mass dampers for NVH reduction. The other downside to drilled rotors is they tend to make a lot of noise.
AnthonyM
AnthonyM
1/4/23 1:51 p.m.
Agreed that HP+ are a good upgrade for a first-timer. When I was going through my 2 years of HPDE's with a nearly stock RX-8, they worked great for me. But now that I can get everything out of a car, they won't last for me. Hell, it's hard to get a stock-ish car to get tires to last, either, so it's all relative.
I LOVE Hawk's High Performance Street 5.0 pads for my road cars and I think a beginner could get by on them for their first few HPDE's, as well.
The DTC30's aren't on those charts, but on my Cayman I found them to hold up to pretty heavy track use and not be completely terrible on the street.  They weren't as noisy as the 60's, although they still dusted a lot and ate rotors when cold.
Also, those pad wear sensors are the worst.  A lot of people just cut off the pigtail and short the two wires with a crimp connector to keep the dashboard light permanently off.  I doubt if anyone on the GRM forum actually relies on pad wear sensors to tell them when their brake pads are getting low.
1/4/23 4:28 p.m.
Blues, Blacks, HP+ -- IMHO pretty much any Hawk pad that isn't a DTC is obsolete other than the HPS, and even those have a new/improved version call "5.0".
1/4/23 5:21 p.m.
HP+ is good for a lap and a half of our local track before fading into oblivion. We named the first turn at the track "the Ferber straight" after a new hire (and experienced autocrosser) went so far off he just about ended up on the interstate.
 I'd never touch them after seeing that.
1/4/23 6:07 p.m.
Was that a stock Miata motor, or a 400 hp turbo car? :)
1/4/23 6:30 p.m.
FM II, so about 250 rwhp. And some sort of street rubber circa 2007, not a cheater 200TW tire.  Still, a lap and a half! This is a kart track, so top speed couldn't have been more than 60 mph on that car.
docwyte
docwyte PowerDork
1/4/23 6:47 p.m.
You literally picked the worst pad for every single situation.  Your experience with miata's is showing, this is not a tiny, underpowered, small tired car.  HP+ make noise and copious brake dust on the street, yet on the track will melt inside of a few laps with an experienced driver, like you.
Do yourself a huge favor and just throw them in the trash.  Run OEM textar pads for the street and a set of PFC08's or 11's on the track.  The drilled rotors are ok, but not as good as a set of Stebro slotted rotors.
I've gotta say, the last few articles you've written on this car have really missed the mark and shown some things that are just flat out wrong, like "cleaning" the radiators.
leec
leec New Reader
1/4/23 8:31 p.m.
Anyone worry about the compatibility of oddball rotor's hardness to various aftermarket pads?  Has to be some pro team has figured out wear, heat dissipation, alloys etc.
deaconblue
1/4/23 9:32 p.m.
You have got to be kidding!  Seriously?  What over engineered German nonsense is that?!?  How about just using slotted or smooth rotors?
RacerBoy75
RacerBoy75 New Reader
1/4/23 9:47 p.m.
I agree with docwyte, just pony up and get the PFC pads that work great on the track. I use the 08's on my Cayman S and have never had any performance issues on the track. They seem to last a long time, and aren't too hard on the rotors, either. They even work pretty well on the street except for the track pad-on-the-street bugaboos of squeaking loudly and dusting like crazy.
madmrak351
madmrak351 Reader
1/4/23 10:25 p.m.
I have seen the NHV pad "lollipops" on V8 Camaro Brembos and a few other applications.
Nockenwelle
Nockenwelle New Reader
1/4/23 10:49 p.m.
Not to harp on Hawk pads (I run DTCs on the race car and love them), but I'll agree with the mediocrity of the HP+. There's a few other contenders in the "trackable street pad" category I'd probably pick first. Offerings from EBC, PFC, Carbotech, and Porterfield warrant consideration. Pad abuse factor really depends on vehicle weight, and that car is not a flyweight.
I never did understand why Porsche put drilled rotors on almost everything. Obviously there's a few engineers on staff who at least know their way around a brake rotor and understand the drawbacks. Drilling holes is not cheaper than not drilling them, so it's not cost. It is marginally lighter, but not enough. Of all the things to concede to the design department...
kaybat
kaybat New Reader
1/4/23 11:24 p.m.
Just went thru this on my Cayman. I switched from Hawk Hp+ to Ferodo 2500's in front. The Ferodo's feel better, but I haven't been on the track with them yet.(They are a little noisier though).
docwyte
docwyte PowerDork
1/5/23 1:07 a.m.
Ferodo DS2500's are ok, up to a point.  Once your pace increases, they're not going to hold up.  Just like any "dual use" pad, they're really not a track pad and eventually it shows.
red_stapler
red_stapler SuperDork
1/5/23 2:43 a.m.
They hold up OK in the sense that they remain functional at the cost of a very rapid wear rate.  I went through a set at NCM in like one Chin weekend.
njDZkHBIRn5zk1n10FXyZwPhItJBSBwmhgu9HaVL673M4W1Gm96xfFIuMuen8gc5
